v vs w rated Kumho tires?
Old 07-10-2002, 11:39 AM
99civic_exSB's Avatar
Default v vs w rated Kumho tires?
What's the difference between v and w rated tires? I am specifically looking at the Kumho Ecsta 205/50/15 tire on stock 96 GSR rims. v is $58, w is $60. Which has the stiffer sidewall? Will I notice a difference? Thanks!
Old 07-10-2002, 02:53 PM
Default Re: v vs w rated Kumho tires? (99civic_exSB)
ttt Anyone? V vs W?
Old 07-10-2002, 02:59 PM
Premium Member
madchiller's Avatar
speed rating.. do a search on the web or check tirerack.com for the acutal speeds the ratings mean.
Old 07-10-2002, 05:37 PM
Y2K Si FBP's Avatar
speed rating
v is upto 149
w is upto 168
z is 149 and up
speed rating also tells (most cases) how stiff the sidewall will be..how much heat the tire can hold.
Old 07-10-2002, 07:19 PM
Vazquez911's Avatar
Default Re: v vs w rated Kumho tires? (Y2K Si FBP)
Buy the Ws... when they arrive they are marked as Z's...
I love em... 712s killer price for good performance!
Old 07-10-2002, 09:48 PM
PatrickGSR94's Avatar
Generally when comparing 2 tires of the same size, the tire w/ the higher speed rating will perform better at all speeds (in the dry at least). i'd go for the W's, can't go wrong for an extra $8.
Old 07-10-2002, 11:07 PM
ALF
ALF's Avatar
The v-rated version has a higher treadwear rating, but will have less overall grip than the w-rated.
Go for the w-rated ones...even those aren't so nice when it comes to handling, but it's better than the v-rated version, nonetheless.
Old 07-11-2002, 09:22 AM
RuskeR's Avatar
Default Re: v vs w rated Kumho tires? (ALF)
Even though your car won't be in the 168mph range I'd still get the w rated tires. It's only $8 bucks. Worth the little extra handling you get.
Old 07-11-2002, 09:50 AM
New User
slickboy's Avatar
Default Re: v vs w rated Kumho tires? (RuskeR)
I bought the Z rated 712's from http://www.TireRack.com. They were the same price as the lower rated tires. You will be sacrificing a small amount of tread life to get the higher speed rating, but the tires will hold up better under abuse. I am very happy that I got the Z rated ones.
Old 07-11-2002, 11:15 AM
Default Re: v vs w rated Kumho tires? (slickboy)
So the general consensus seems to be to go with the W's. Any idea how much tread life I'd be sacrificing? Also will the W's be much louder than the V's? Just wondering. Thanks guys!
accord64
09-11-2007 02:45 AM
B18C_EJ8
01-24-2007 11:19 AM
DC2IntegraTypeR
03-18-2004 04:36 PM
O1 Coupe
04-06-2002 03:44 PM
D-SPEED
11-28-2001 05:06 AM
Quick Reply: v vs w rated Kumho tires?
