SOHC timing belt teeth????
Old 04-03-2006, 11:39 AM
RICE POLICE SIP's Avatar
Default SOHC timing belt teeth????
Does anyone have a run down of all the SOHC timing belts and how many teeth they have? Or where I can find the info? Anywhere from EF's to the 7th gen civics... TIA
Old 04-03-2006, 01:20 PM
Default Re: SOHC timing belt teeth???? (Split Image Prez)
I put a 92-95 civic head (d15b7) on a 96-97 del sol block (D16y7) and now the y7 timing belt is to short... anyone know of any longer belts?
Old 04-04-2006, 08:59 AM
well after a little research and counting of teeth on timing belts I find that on the 91 CRX si 1.6L belt you have a 106 tooth belt and a 107 tooth belt... The D16Y7 belt has 104 teeth... I'm still doing a little more research but I ended up buying the 107 tooth belt...
Old 04-04-2006, 02:56 PM
anyone know any of the other belt tooth counts?
Old 04-04-2006, 02:58 PM
SVOboy's Avatar
Bump for fun, this'd be good info to put in a FAQ.
Old 04-04-2006, 03:24 PM
92hatchling's Avatar
Default Re: (SVOboy)
it the b7 belt your looking for you almost always use the belt for the head you use
Old 04-04-2006, 03:51 PM
Default Re: (92hatchling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchling &raquo;</TD></TR><TR><TD CLASS="quote">it the b7 belt your looking for you almost always use the belt for the head you use</TD></TR></TABLE>
That's what I was thinking too, but then I was thinking if it's a 1.5L block why would the belt be longer.. I stopped by Auto Zone and the CRX si belt have the same part number as the D15b7 belt.. But one is a 1.5L and the other is a 1.6L also..... When they pull up the 91 CRX 1.6L in the computer it asks you 106 or 107 tooth... Why would they be different?
Old 04-04-2006, 04:03 PM
mc
mc's Avatar
Default Re: (Split Image Prez)
the d15z1 belt is 103 teeth
edit:
actually I found some more after searching a little
The VX timing belt has 103 teeth, where as the Z6 timing belt has 104 teeth, and the B7 belt 106 teeth.
Modified by mc at 9:12 PM 4/4/2006
Old 04-05-2006, 08:27 AM
Default Re: (mc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mc &raquo;</TD></TR><TR><TD CLASS="quote">the d15z1 belt is 103 teeth
edit:
Modified by mc at 9:12 PM 4/4/2006</TD></TR></TABLE>
WOW 103 lol Thanks for the info! I put the 106 tooth belt on and it seems to be just fine... knock on wood... LOL
Old 06-10-2007, 09:01 PM
Metal Head's Avatar
Default Re: (RICE POLICE SIP)
does vtec and non vtec affect the belts length? I have a d15B vtec, im looking for a belt for it, I assume the d16z6 belt would work cuz its VTEC, so I have to use a 1.5L belt, does it HAVE to be vtec? or can I buy a 1.5L non-vtec belt??
airikkCRX
04-02-2010 08:29 AM
unbelievableEG
11
09-26-2007 08:41 PM
175Shot4Door
11-06-2006 12:50 PM
eg6T
08-14-2005 02:35 AM
blayzenazn
02-18-2002 07:51 AM
Quick Reply: SOHC timing belt teeth????
