Steering wheel squeaks loudly when turning left...
Old 12-18-2005, 05:15 PM
transpar_nt's Avatar
Default Steering wheel squeaks loudly when turning left...
I've got a 92 eg8 and my steering wheels squeeks pretty loudly whenever I turn left. It ONLY happens when I turn left, and it ALWAYS happens when its cold outside. In the middle of the summer I don't really notice it, so if its happening then its a lot quieter. It isn't any harder to turn than usual and I've noticed no other problems with it, but its really annoying and embarrasing if I have passengers in the car. Anyone know what this could be?
EDIT: For clarification, the sound is coming from behind the steering wheels somewhere. There is nothing wrong with the suspension/tierods or anything, and it can only be heard inside the cab.
Modified by transpar_nt at 8:30 PM 12/18/2005
Old 12-18-2005, 05:24 PM
RIP 1032
life sux die's Avatar
Default Re: Steering wheel squeaks loudly when turning left... (transpar_nt)
check all your boots in the suspension (axels, steering rack, etc...) also, check your steering column maybe it needs to be greased up a bit?
Old 12-18-2005, 05:33 PM
Default Re: Steering wheel squeaks loudly when turning left... (life sux die)
The thing I can't figure out is why it only happens when turning left. If it needed greasing, wouldn't it make sound both ways?
Old 12-18-2005, 05:50 PM
inline4's Avatar
with the key all the way to the on position(this will release the steering lock)
have a friend turn the steering wheel left while you stick your head under the wheel and see where the noise is coming from.
i had a loose bolt under there before, can't remember if it made any noise, but it was just loose, and I think it was somehow attached to a spring on the steering rack.
that could be your problem, that spring might be compressing and decompressing when you turn left.
Old 12-18-2005, 06:04 PM
old man neri's Avatar
sounds like a power steering issue, either the pump or the rack..........
scoobyghost
08-21-2003 08:58 PM
B18Redline
06-13-2003 04:50 AM
Malgerus
03-28-2003 10:53 PM
Big Teggie
02-23-2003 09:06 AM
Quick Reply: Steering wheel squeaks loudly when turning left...
