Honda S2000 Honda S2000
What does EPS mean on your dash?
Old 11-16-2005, 05:47 AM
S2GtizNUtz's Avatar
Default What does EPS mean on your dash?
Went back this morning and whack the Map sensor. Reset the ECU. And did the idle reset thing. Where i ran the car at a consistent 3000rpm until the fan came on. Now the EPS comes on in the dash. What does that mean?
Old 11-16-2005, 06:18 AM
Francesco's Avatar
Default Re: What does EPS mean on your dash? (S2GtizNUtz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2GtizNUtz &raquo;</TD></TR><TR><TD CLASS="quote">Went back this morning and whack the Map sensor. Reset the ECU. And did the idle reset thing. Where i ran the car at a consistent 3000rpm until the fan came on. Now the EPS comes on in the dash. What does that mean? </TD></TR></TABLE>
isn't EPS the electronic steering system? Electronic rack and Pinion Steering?
Old 11-16-2005, 06:33 AM
jolt-tsp's Avatar
Default Re: What does EPS mean on your dash? (Francesco)
Searched google and found this. It's refering to an NSX but the systems are pretty much the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://www.nsxprime.com/FAQ/Technical/eps.htm &raquo;</TD></TR><TR><TD CLASS="quote">
If a problem occurs, the control unit turns the system off by actuating a fail-safe relay in the power unit. This eliminates all power assist, causing the system to revert back to manual steering. A dash EPS warning light is also illuminated to alert the driver. To diagnose the problem, a technician jumps the terminals on the service check connector and reads out the trouble codes.
Old 11-16-2005, 10:30 AM
vortechstook's Avatar
"Electronic Power Steering"
we don't have a hydrolic system like civics/integra's/etc do
Old 11-17-2005, 11:51 AM
* B A N N E D *
Mr. Projekt's Avatar
Did you touch the EPS box at all?
Old 11-17-2005, 12:07 PM
WowOzYouRock's Avatar
Default Re: What does EPS mean on your dash? (Slideways2000)
EPS ... Eat , Poo, and Sleep
the light is basically saying, youre a lazy bastard
Old 11-17-2005, 12:16 PM
solsurvivor's Avatar
Default Re: What does EPS mean on your dash? (Y2K_S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">EPS ... Eat , Poo, and Sleep
the light is basically saying, youre a lazy bastard </TD></TR></TABLE>
LOL
Old 11-17-2005, 08:41 PM
SuzukaBlueAP2's Avatar
no no no that's only if you buy an 06 and enjoy the drive-by-wire. that's a lazy bastard.
what's a REALLY lazy bastard, is anyone who buys a new car because it has "rain sensing wipers". Why don't we just make toilets that wipe our asses?
Old 11-18-2005, 12:38 AM
* B A N N E D *
Default Re: What does EPS mean on your dash? (ScreaminTeg)
JDM toilets spray your *** with a stream of water. You're old news man.
Old 11-18-2005, 04:32 AM
jolt-tsp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">JDM toilets spray your *** with a stream of water. You're old news man.</TD></TR></TABLE>
Those things are so ridiculous. Takes like 15 minutes to "wipe"! Plus if its laid on thick, I can't imagine the sprayers can get it all. It's like a Jeep that just went mudding going through one of those gas station pressure spray washes.
Old 11-18-2005, 04:55 AM
hypnosisracing's Avatar
Default Re: What does EPS mean on your dash? (jolt-tsp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Why don't we just make toilets that wipe our asses?</TD></TR></TABLE>
They do...if you have the money, you can afford to be as lazy as you want.
Old 11-18-2005, 06:58 AM
Nishant's Avatar
Default Re: What does EPS mean on your dash? (hypnosisracing)
with infinite $, you can do afford anything
Old 11-18-2005, 09:45 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">
Those things are so ridiculous. Takes like 15 minutes to "wipe"! Plus if its laid on thick, I can't imagine the sprayers can get it all. It's like a Jeep that just went mudding going through one of those gas station pressure spray washes.</TD></TR></TABLE>
I heard the girls enjoy the front sprayers. Damn JDM freaks.
Old 01-17-2006, 10:46 PM
dwolsten's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnosisracing &raquo;</TD></TR><TR><TD CLASS="quote">They do...if you have the money, you can afford to be as lazy as you want.</TD></TR></TABLE>
It's not just laziness. For older people, it's better to use a water sprayer to clean up than toilet paper, because it helps avoid hemorrhoids. I'm not making this up.
iLOVEthatEMone
10-11-2008 07:32 AM
wicked_b16eg
12-29-2007 07:18 PM
evans_art
06-21-2007 03:11 AM
essex
Acura TL, RL & ZDX
12-19-2004 02:15 PM
RUBZERK
07-14-2003 12:50 PM
Quick Reply: What does EPS mean on your dash?
