Wher is my radiator fan relay?? 1994 integra ls
Old 05-28-2005, 12:51 PM
Turboredteg's Avatar
Default Wher is my radiator fan relay?? 1994 integra ls
My radiator fan will not turn on, I have a 1994 ls so I have already checked the fuse and its good, the fan its self is good, the fan switch is good so I am almost possitive that it is the relay. My problem is locating the fan relay. I need a pic or something and for a 1994-95 other then that its different please help. thanks
Old 05-28-2005, 01:02 PM
Cogent Argument Enthusiast
Uncle Ben's's Avatar
Default Re: Wher is my radiator fan relay?? 1994 integra ls (Turboredteg)
i dont know about g3s, but the relay on my 92 integra is right under the fan. my radiator fan never comes on, which i think is a sign that the coolant system is very effective. my temp gauge has never risen above 45%.
Old 05-28-2005, 01:06 PM
Default Re: Wher is my radiator fan relay?? 1994 integra ls (benb18a)
My gauge has never gone above the half way mark but Right now its uhh like 93 degrees yeah I live so cal so if I don't fix it now I am going to end up messin something up
Old 05-28-2005, 01:09 PM
that shouldnt matter; ive went to the track when it was over 90 out, and ran my car 10 times in 3 hours and it still doesnt overheat. my friends integra is exactly the same; our fans never come on, even if its 100+ outside.
Old 05-28-2005, 01:12 PM
20-30 minutes on the I-15 with no fan and no movement = hot and on the verge of over heating If I am just drivng on the open road then it stays really cool but 20 min. of nothing but stop and go traffic it starts getting a little warm
Old 05-28-2005, 02:22 PM
anyone please.... need to know thanks
Old 05-28-2005, 05:08 PM
Well I finaly found the fan relay it is in the fuse box in the engine bay. It will be the one that is near the battery it is in the far back. Also the reason I was looking for this realy is that my fan would not kick on, and I would start to over heat. Well I checked the fan switch,I checked the fuse, the fan, and all grounds. Well for those of use who didn't know they also had a fuse under the dash . It is a 7.5. If you think that you may have the same problem, then a good way to tell is if your heater/air will not work either (because they run off the same fuse). I hope this helps someone else cause I spent half a day testin stuff with a multi-meter for nothin but now I am smart and have a working fan
Old 05-28-2005, 05:11 PM
worditsmenick's Avatar
its in the fuse box by the battery. there is also a relay hidden in the dash somewhere.
double check your fan sensor switch at the themostat and the themostat itself.
mine went out and the radiator decided to let the pressure out its own way. by breaking the top loose.
get it checked and fixed. you need that fan blowing on the radiator.
hope this helps.
Old 05-28-2005, 05:13 PM
Default Re: (worditsmenick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by worditsmenick &raquo;</TD></TR><TR><TD CLASS="quote">its in the fuse box by the battery. there is also a relay hidden in the dash somewhere.
hope this helps. </TD></TR></TABLE>
haha i was typing this as you were typing that. great to hear.
Old 05-29-2005, 11:39 AM
Hey at least you posted cause there are not to many that do so thanks
Old 05-29-2005, 11:43 AM
SCAM ARTIST
EV1L SI's Avatar
Default Re: (Turboredteg)
a common thing on 3rd gen tegs if for the radiator switch to go out. its located behind the distributor, down towards the intake manifold flange. mine went out in my GSR and i ended up sticking a paper clip in the harness side plug to keep the fan on all the time. ghetto
Old 05-29-2005, 11:48 AM
Default Re: (EV1L SI)
hey it beats paying 45-60 for a new on from honda
InterludeTypeR
06-20-2009 08:13 PM
92-LS-Civic
10-18-2005 10:09 PM
DragII
03-27-2002 09:49 AM
Quick Reply: Wher is my radiator fan relay?? 1994 integra ls
