B16 head vs. B18 head
Old 04-08-2003, 06:56 PM
mattcxb18's Avatar
Default B16 head vs. B18 head = Good Info
On another post I read that the B18 had better flow then the b16.
I Just wanted to say somethings about that. Below is a chart from the post earlier.
B16 is better, or the same...Look at that graph again. I just noticed something. Look at the valve lift. The b18 doesn't beat the b16 until .450 valve lift.. I reallllly doubt that ANY honda unless it's got a BIG *** cam is gonna have .450 valve lift. anything in the .450 range of valve lift is a serious cam usually. cranes BIGGEST BADDEST b18 cam only has .472intake / .457 exhaust lift. And that is a race only cam look what crane says about it.
Race Only Roller Cam
Pro stock - all motor - naturally aspirated
Pro class modifications needed
Check valve to piston clearance
Minimum compression ratio 12.5:1
Anyways...With a regular valve lift number, the b16 out flows the b18, or ties with it. I'de like to see a cam that has .500 lift like that chart shows. Just something to think about.
If you wanna check it out. go to Acura VTEC Cams and go to the LAST cam, it's the baddest one. And according to that chart, the b18 outflowed the b16 overall by 2 cfm.
2 cfm isn't ****. You wouldn't even notive 2 cubic foot per MINUTE. So i guess it doesn't matter which head you go with. Just get the one with higher compression. Plus i wonder how accurate that chart is anyways. That's such a close flow number, I wonder if it's correct. 2cfm is sooo tiny.
[Modified by mattcxb18, 11:56 PM 4/8/2003]
Old 04-08-2003, 07:14 PM
SOUNDEFFECTS's Avatar
Default Re: B16 head vs. B18 head (mattcxb18)
good info
Old 04-09-2003, 09:34 AM
mattcxb18's Avatar
Default Re: B16 head vs. B18 head (SOUNDEFFECTS)
Also, I would assume that this was a test just thru one port. Not like that makes any difference though.
Old 04-09-2003, 09:47 AM
Chris y0!'s Avatar
exactly. the range of lift that normal camshafts utilize is where the b16 outflows the b18.
the b18 head only outflows the b16 head after .475 valve lift. no streetable cam lifts that much.
the b16 head flows a little better than the b18 head
Old 04-09-2003, 10:05 AM
white99gsr's Avatar
Default Re: B16 head vs. B18 head (Spoon Hybrid)
Ok, the B16 head is essentially an ITR head without the polishing, no wonder it outflows the GSR head........NA. The GSR head on the other hand is a far better flowing head for FI. It has better a better swirl effect because of the dome shape.
Old 04-09-2003, 10:11 AM
Chris y0!'s Avatar
Default Re: B16 head vs. B18 head (white99gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white99gsr &raquo;</TD></TR><TR><TD CLASS="quote">Ok, the B16 head is essentially an ITR head without the polishing, no wonder it outflows the GSR head........NA. The GSR head on the other hand is a far better flowing head for FI. It has better a better swirl effect because of the dome shape.</TD></TR></TABLE>
that's fabulous. we are talking about NA here.
Old 04-09-2003, 10:32 AM
New User
976's Avatar
Is that a 1st generation, or 2nd? I take it that it is a JDM head/block since it's B16.
Old 04-09-2003, 11:55 AM
TORQUEbeast's Avatar
good to know.
Old 04-09-2003, 03:25 PM
mattcxb18's Avatar
How is the same head going to flow better with FI or NA? It should not matter. The flows would come down to the port size and cam lift. It should not matter if air is being pushed or pulled in.
Old 04-11-2005, 11:34 AM
EgxHaTcHxGsR's Avatar
uhmm... so if u put a b16 block with gsr head will it be slower or same as just a whole b16?
Old 04-11-2005, 12:39 PM
As long as I dont have to take out any more Metal Gears
rukawa1one's Avatar
Default Re: B16 head vs. B18 head = Good Info (mattcxb18)
good info, thatsexactly why i'm leaning towards a b16 instead of a b18
Old 04-11-2005, 12:41 PM
civiccpedx's Avatar
Default Re: B16 head vs. B18 head = Good Info (rukawa1one)
nice info, HT needs more techies like you
Old 04-13-2005, 04:11 AM
HatchEh2's Avatar
Default Re: B16 head vs. B18 head = Good Info (civiccpedx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgxHaTcHxGsR &raquo;</TD></TR><TR><TD CLASS="quote">uhmm... so if u put a b16 block with gsr head will it be slower or same as just a whole b16?</TD></TR></TABLE>
someone should answer this because id like to know aswell
Old 04-13-2005, 05:08 AM
hisownhero's Avatar
mad good info Matt
Old 04-13-2005, 06:53 AM
eg crunkmonster's Avatar
you would drop raise the compression a little bit
Modified by eg crunkmonster at 10:46 PM 10/30/2005
Old 05-19-2005, 02:41 AM
TEAMTUNNELVISION's Avatar
Good reading you did on that chart I wouldnt mind seing that chart my self, but the only reason I think they say the head is better on the g.s.r than the b16 is the fact that the g.s.r head has more compression due to a tighter quench area that gives it more compression. I know you all motor cats love the whole compression deal. As a matter of fact I have a g.s.r head I would like to trade for a b16 head or type r head. Im a boost guy and I need lower compression. Maybe somone could help ? 347-386-7065 Will
http://WWW.TEAMTUNNELVISION.COM
Old 05-19-2005, 09:13 AM
Mr. Indecisive
EJ8VTEC's Avatar
Default Re: B16 head vs. B18 head (TEAMTUNNELVISION)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEAMTUNNELVISION &raquo;</TD></TR><TR><TD CLASS="quote">Good reading you did on that chart I wouldnt mind seing that chart my self, but the only reason I think they say the head is better on the g.s.r than the b16 is the fact that the g.s.r head has more compression due to a tighter quench area that gives it more compression. I know you all motor cats love the whole compression deal. As a matter of fact I have a g.s.r head I would like to trade for a b16 head or type r head. Im a boost guy and I need lower compression. Maybe somone could help ? 347-386-7065 Will
http://WWW.TEAMTUNNELVISION.COM</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg cookiemonster &raquo;</TD></TR><TR><TD CLASS="quote">
you would drop the compression a little bit
K u guys said 2 different things...
Old 05-19-2005, 10:43 AM
vacantskies88's Avatar
Default Re: B16 head vs. B18 head (EJ8VTEC)
the b16 flows better but the b18 yields more compression, no?
Old 05-19-2005, 10:49 AM
honda etr (vw)'s Avatar
son i would go with a b-16 b1 c5 11d single fire that **** i off the hook
Old 05-19-2005, 11:02 AM
dantastic's Avatar
i thought it was common knowledge that the PR3 (B16a, B18C-R) head flows better than P72 GSR head....
Old 05-19-2005, 11:31 AM
mattssi's Avatar
Default Re: (dantastic)
the p72 head will yield higher compression.
Old 05-19-2005, 11:32 AM
mattssi's Avatar
Default Re: B16 head vs. B18 head = Good Info (honda etr (vw))
Your dumb. Not a good way to start you stay here.
Old 05-19-2005, 11:39 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcxb18 &raquo;</TD></TR><TR><TD CLASS="quote">On another post I read that the B18 had better flow then the b16.
I've always heard the b16 was better. In fact I don't think i've ever heard anyone say the b18 is better. Good post though.
Old 05-19-2005, 12:03 PM
92b16vx's Avatar
That is so *** backwards.
Old 05-19-2005, 12:06 PM
mwieczorek43's Avatar
Default Re: B16 head vs. B18 head = Good Info (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">i thought it was common knowledge that the PR3 (B16a, B18C-R) head flows better than P72 GSR head....</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">I've always heard the b16 was better. In fact I don't think i've ever heard anyone say the b18 is better. Good post though.</TD></TR></TABLE>
Im with these two. This post is some shocking revelation
Quick Reply: B16 head vs. B18 head
