Valve Cover Torque Specs
Old 03-31-2002, 01:27 PM
capcon83's Avatar
Default Valve Cover Torque Specs
Does anyone know what the torque is for the valve cover
capcon83 is offline
Old 03-31-2002, 01:28 PM
Jason's Avatar
Default Re: Valve Cover Torque Specs (capcon83)
should be like 18-20 ft/lbs...just dont make it too tight, I've cross-threaded, then snapped a few
hand tight is fine
Jason is offline
Old 03-31-2002, 01:34 PM
KF_S2000's Avatar
Default Re: Valve Cover Torque Specs (Jason)
hand tight is fine
Whoa there muscles, I'm surprised you haven't snapped more than a few with those torque specs. Just go 7.2 lb/ft (got that out of a Helms manual). If you work on your car, you should definitely get one of these.
KF_S2000 is offline
Old 03-31-2002, 02:23 PM
kenji's Avatar
Default Re: Valve Cover Torque Specs (kf_Type-R)
Here we go again...
I would not torque your valve cover nuts. Unless you have a pretty accurate 1/4" torque wrench I would not even bother. Just snug them down with a 1/4" ratchet.
I can't even remember how many people have broken studs from trying to torque down these nuts. Most torque wrenches are VERY inaccurate at this low of a torque value.
Some things need to be torqued and some don't. Valve cover nuts are one of the things that don't need to be torqued. Main cap bolts, cam cap bolts, rod bolts, and motor mount bolts are some of the bolts/nuts that need to be torqued. Good luck.
BTW, kf_Type-R is correct on the 7.2 lbs-ft torque value.
-kenji
[Modified by kenji, 3:24 PM 3/31/2002]
kenji is offline
Old 03-31-2002, 03:37 PM
1 2 NV's Avatar
2 grunts always does the trick. i say small bolt, 2 small grunts jk, snug em down.
1 2 NV is offline
Old 03-31-2002, 03:38 PM
kkim's Avatar
Default Re: Valve Cover Torque Specs (kenji)
7.2lbs/ft sounds right. I would use a 1/4inch torque wrench to install. also, there is a certain torque sequence for these bolts to prevent head gasket leakage and they should be done in steps. this also out of the helms manual.
kkim is offline
twkdCD595
10-22-2021 02:10 PM
BB6racer
01-19-2006 04:48 PM
my93hatch
02-16-2005 04:19 PM
memphiss13
12-12-2001 08:21 AM
1fastGSR
10-01-2001 04:20 PM
Quick Reply: Valve Cover Torque Specs
