B20 ALLMOTOR NONVTEC street car 12.12 @ 111 World fastest????
Old 10-14-2004, 06:38 PM
nonvtecallmotor's Avatar
Default B20 ALLMOTOR NONVTEC street car 12.12 @ 111 World fastest????
Went to Cecil county dragway last night with my 91 CRX SI with an allmotor B20 nonvtec. Ran a
12.12 @ 111 with a 1.65 60'
The set up B20 stock bore, 13.1 Arias pistons, Crower rods, 00 B20 head race ported, Rev .20 over ss valves, Rev springs and retainers, Crower 405 cams, non ported Type - R intake, Type - R t-body, Header Tech Header, Tec II EMS. All the machine work done by KODD RACING ENGINES Hampstead Maryland
Still working some bugs out of it. Hoping to run 11's very soon.
I was wondering if its the fastest allmotor B20 nonvtec. If not I'd like to know who and how fast.
Old 10-14-2004, 06:39 PM
Banned
HondaGuy02's Avatar
Default Re: B20 ALLMOTOR NONVTEC street car 12.12 @ 111 World fastest???? (nonvtecallmotor)
impressive
Old 10-14-2004, 07:04 PM
DEVIOUS_EG*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor &raquo;</TD></TR><TR><TD CLASS="quote"> The set up B20 stock bore, 13.1 Arias pistons, Crower rods, 00 B20 head race ported, Rev .20 over ss valves, Rev springs and retainers, Crower 405 cams, non ported Type - R intake, Type - R t-body, Header Tech Header, Tec II EMS. </TD></TR></TABLE>nice set up.. 12.1! any dyno #'s?
Old 10-14-2004, 07:23 PM
Default Re: B20 ALLMOTOR NONVTEC street car 12.12 @ 111 World fastest???? (DEVIOUS_EF*)
Ive dynoed it but was disappointed. It made 195/138 @ 9000. The first few dyno pulls said it made 267 ftq?. So I'm not sure what is up with the low dyno #'s.
But my old motor made 198/148 but only ran 12.48 @ 107 in the same car. The car weights about 2000 w/driver.
With a 2000lbs car at 111mph the motor has to make somewhere around 210-220 I would think?
Old 10-15-2004, 02:41 PM
hybridpatient95's Avatar
bump for the fast nonvtec b20 i wish i had that
Old 10-15-2004, 02:53 PM
Runnerdown's Avatar
What tranny are you running?
Old 10-15-2004, 03:42 PM
Default Re: (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">What tranny are you running?</TD></TR></TABLE>I'm using a 00 si b16a with open diff. I've used all kinds of trans combos and none made a difference.
Old 10-15-2004, 03:59 PM
ericrx_88's Avatar
Default Re: (nonvtecallmotor)
great times. i know hocus pocus hada b20 allmotor but thats was a drag car i bet you do have the fastest street b20 novtec good job
Old 10-15-2004, 04:02 PM
Default Re: (ericrx_88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericrx_88 &raquo;</TD></TR><TR><TD CLASS="quote">great times. i know hocus pocus hada b20 allmotor but thats was a drag car i bet you do have the fastest street b20 novtec good job</TD></TR></TABLE>Do you know what it ran?
Old 10-15-2004, 04:21 PM
H25
H25's Avatar
good job nonvtecallmotor... however we had a 94 integra LS that ran 12.00@109.97 with a 1.59 60 foot. back in 1997. it had stock sleeves. 82mm bore 11:1 compression, dpr full race head, gude full race cams, valvetrain, honda ecu retuned, 66mm throtle body 4 inch intake, type R intake manifold, and a gsr tranny, and a few other goodies.... Its been so long, I think you will beat that time shortly though if you keep trying.. good luck to you.
Old 10-15-2004, 05:57 PM
ericrx_88's Avatar
Default Re: (MHRacing-310)
i think it ran low 11 but it was all out race
Old 10-15-2004, 10:11 PM
Fresh start for 09'
ATS*EK24's Avatar
that is quick!
real quick!
for sure the fastest ALL MOTOR Non-VTEC i know of on the streets
11-sec pass is just a matter of time.
How do u like the 405's?
Is there a big difference in power over the 404's?
Also what ocatane you running with those 13-1 slugs?
thanx
Old 10-15-2004, 10:15 PM
putitinthebucket's Avatar
Default Re: B20 ALLMOTOR NONVTEC street car 12.12 @ 111 World fastest???? (JDMboy)
wow i might dump my ls and build a b20. So question does that mean that u can use ls cams on a b20 . I know people say they are the same but are they that close?
Old 10-15-2004, 11:07 PM
StorminMatt's Avatar
Default Re: B20 ALLMOTOR NONVTEC street car 12.12 @ 111 World fastest???? (putitinthebucket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by putitinthebucket &raquo;</TD></TR><TR><TD CLASS="quote">wow i might dump my ls and build a b20. So question does that mean that u can use ls cams on a b20 . I know people say they are the same but are they that close? </TD></TR></TABLE>
LS cams fit in a B20. After all, the B20 and LS share the same head.
Old 10-16-2004, 04:18 AM
H25
H25's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericrx_88 &raquo;</TD></TR><TR><TD CLASS="quote">i think it ran low 11 but it was all out race
your information is wrong... it was a street race car only, untill it got sponsored by dpr...And no it did not run low 11 although it could have eventually. but the car was sold. and then shortly retired from racing. bottom line it was done 8 years ago. NON VTEC INTEGRA end of story..
Old 10-16-2004, 08:00 AM
teg92's Avatar
Default Re: B20 ALLMOTOR NONVTEC street car 12.12 @ 111 World fastest???? (Manuel)
Damn now I kick myself for not taking out my 223whp/176wtq nonvtec B20 out to the track when I had it
Great times.
Old 10-16-2004, 08:50 AM
r_Senik's Avatar
Default Re: B20 ALLMOTOR NONVTEC street car 12.12 @ 111 World fastest???? (teg92)
damn thinkin about a b20 now
Old 10-16-2004, 11:26 AM
efgarage's Avatar
nice times man..11sec pass just around the corner!!
Old 10-16-2004, 11:45 AM
hybrid_vtec's Avatar
Nice Times and hp #'s! It is the fastest I have heard for the B20 Non-vtec's!
I have questions for you about running the 405's! What did you have to do to run those cams! I am running 404's and P30 Pistons currently but want to go to 405's and CTR's in my B18b!
Old 10-17-2004, 02:27 PM
C2Imports's Avatar
Default Re: B20 ALLMOTOR NONVTEC street car 12.12 @ 111 World fastest???? (hybrid_vtec)
195 whp is accurate for this timeslip, 210 would put you in the 11's, im pushing 192 running a similar time
Old 10-17-2004, 03:29 PM
Default Re: B20 ALLMOTOR NONVTEC street car 12.12 @ 111 World fastest???? (towsondragcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by towsondragcrx &raquo;</TD></TR><TR><TD CLASS="quote">195 whp is accurate for this timeslip, 210 would put you in the 11's, im pushing 192 running a similar time </TD></TR></TABLE>Its in a STREET CAR 91 SI FULL GLASS and FULL INTEROR FROM TWO FRONT SEATS FOWARD.
Old 10-18-2004, 01:21 PM
C2Imports's Avatar
with skinnies on the rear and running slicks? stop kidding yourself yeah you'll run street class but you trailer the car on your tow dolly, everyone that goes down to the parkway knows that.
Why only go half way? why not make it a full race car instead of trying to hold on to the title " street car " when deep down you know its not streetable? get serious.
Old 10-18-2004, 02:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by towsondragcrx &raquo;</TD></TR><TR><TD CLASS="quote">with skinnies on the rear and running slicks? stop kidding yourself yeah you'll run street class but you trailer the car on your tow dolly, everyone that goes down to the parkway knows that.
Why only go half way? why not make it a full race car instead of trying to hold on to the title " street car " when deep down you know its not streetable? get serious. </TD></TR></TABLE>You dont know WHAT THE **** YOUR TALKING ABOUT. I HAVE DRIVEN IT ON THE STREET MORE THEN ANY ******* CAR IN MY CLASS. I will drive it anywhere for the right amount of money. I STOPPED DRIVEN IT ON THE STREET BECAUSE ITS A COP MAGNIT. I ALSO HAVE ANOTHER CAR THAT I ONLY RUN ON THE STREET.
IF IT WAS A RACE CAR IT WOULD BE A HELL OF ALOT FASTER.
PS It didnt have skinnys on it when I made that pass.
Old 10-18-2004, 02:50 PM
SlOwDc2-R's Avatar
nice time very impress dont let the hater say anything with that set up eveything about right so keep us posted when you hit 11s
Old 10-18-2004, 02:56 PM
Default Re: B20 ALLMOTOR NONVTEC street car 12.12 @ 111 World fastest???? (SiR-EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR-EK &raquo;</TD></TR><TR><TD CLASS="quote">nice time very impress dont let the hater say anything with that set up eveything about right so keep us posted when you hit 11s </TD></TR></TABLE>Thanks I will def. keep everyone posted.
Quick Reply: B20 ALLMOTOR NONVTEC street car 12.12 @ 111 World fastest????
