my wastegate stays open at idle :(
Old 07-11-2004, 12:42 AM
egturbo's Avatar
Default my wastegate stays open at idle :(
sup guyz my wastegate stays open at idle and boost doesnt kick in till around 5k rpms. what is wrong? plz help thanks. its a tial style wastegate 38mm
do i need that o ring? can't find anywhere to get it at.
ok i think i do already have a valve seat. but i opened up the wastegate and found out one out of four lil allen screws are missing. can that be the problem? when i push the thingy up and down air leaks out of one of the missing holes. tell me what u guyz think.
u see those three lil screws? its missing one of those sorry for the bad quality pics took from camera phone
Modified by egturbo at 9:36 PM 7/15/2004
Old 07-11-2004, 02:58 AM
turbopimp's Avatar
Default Re: my wastegate stays open at idle :( (egturbo)
Assuming the wastegate is not defective, the only way it could be bleeding or leaking exhaust at idle is if you have a vacuum signal going to the top port or neglected to put in the valve seat between the gate and manifold.
Old 07-11-2004, 03:18 AM
Firewerks's Avatar
Default Re: my wastegate stays open at idle :( (turbopimp)
Have you figured out the problem yet? and what kind of wastegate is it?
Old 07-11-2004, 11:38 AM
egturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbopimp &raquo;</TD></TR><TR><TD CLASS="quote">Assuming the wastegate is not defective, the only way it could be bleeding or leaking exhaust at idle is if you have a vacuum signal going to the top port or neglected to put in the valve seat between the gate and manifold.</TD></TR></TABLE>
yeah about it used and i see a gap betweeen the valve and the falnge. is there a place i can get that seal? 38mm tial style wastegate.
Old 07-11-2004, 01:34 PM
H-T White Ops
Frozen E's Avatar
go to a parts store and buy some gasket material. Make your own. Razor knife and some scissors.
Do you have that ring in there? If you do you'll know what I'm talking about. Turbopimp called it the valve seat.
Old 07-11-2004, 08:59 PM
turbopimp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo &raquo;</TD></TR><TR><TD CLASS="quote">
yeah about it used and i see a gap betweeen the valve and the falnge. is there a place i can get that seal? 38mm tial style wastegate.</TD></TR></TABLE>
I think those knock-off Tials are sold on Ebay by SSAutoChrome. You might want to contact them about purchasing the ring. If not, then the Tial piece might work, but I'd check with someone first to make sure 100% about compatability.
Old 07-11-2004, 09:01 PM
J337_UNIT's Avatar
ok quick question.. which port on the gate did u hook the vacuum line up to?
Old 07-11-2004, 10:12 PM
egturbo's Avatar
Default Re: my wastegate stays open at idle :( (J337_UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">ok quick question.. which port on the gate did u hook the vacuum line up to?</TD></TR></TABLE>
i hooked up a tube from the side of the wastegate to the turbo fitting
Old 07-12-2004, 05:26 AM
Dr Pooface's Avatar
tial "style"? Maybe that's your problem. My genuine tial stays closed at idle.
Old 07-12-2004, 08:12 AM
TRUST8383's Avatar
i hooked up a tube from the side of the wastegate to the turbo fitting </TD></TR></TABLE>
Take that vacuum line off the turbo fitting, and route it to a vacuum source after the throttle body (ie:somewhere off the intake manifold) I bet you it'll work after that. We had this problem last night on my buddies civic. Then go get a plug for the port on your compressor housing.
Old 07-12-2004, 08:16 AM
J337_UNIT's Avatar
Default Re: my wastegate stays open at idle :( (TRUST8383)
did u try and check the spring inside the wastegate?
Old 07-12-2004, 10:21 AM
egturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">did u try and check the spring inside the wastegate?</TD></TR></TABLE>
nope how do u do that? and imma try that vacuum source thingy once i get my car back from the shop not gonna have my car for bout 2 weeks
Old 07-12-2004, 08:30 PM
DENCIO's Avatar
bump for this guy cuz I have the same problem right now....
Old 07-12-2004, 08:55 PM
J337_UNIT's Avatar
open up the wastegate and check to make sure the diaphragm and spring are both seated properly.. and make sure there are no holes in the diaphragm. just undo all of the allen bolts around the housing but make sure u hold it down tight.. otherwise the spring pressure will make the top of the housing fly off
Old 07-13-2004, 07:21 PM
DENCIO's Avatar
got my problem fix today, damn valve seat ring...somebody hit me on the head...
thanks to camp1320.com for technical support Tom..
Old 07-13-2004, 07:26 PM
egturbo's Avatar
Default Re: my wastegate stays open at idle :( (hookonboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hookonboost &raquo;</TD></TR><TR><TD CLASS="quote">got my problem fix today, damn valve seat ring...somebody hit me on the head...</TD></TR></TABLE>
good job.. getting my car back fromt he shop tomorrow. hopefully i can fix my problem
Old 07-13-2004, 07:27 PM
DENCIO's Avatar
good job.. getting my car back fromt he shop tomorrow. hopefully i can fix my problem </TD></TR></TABLE>
good luck with your car bro hope you get your car fix..
Old 07-14-2004, 12:49 PM
egturbo's Avatar
yep got my car back its so slow. doesnt spool spools but at high rpm's only sucks.
Old 07-14-2004, 01:10 PM
DENCIO's Avatar
^^how's your wastegate?
Old 07-14-2004, 03:03 PM
egturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hookonboost &raquo;</TD></TR><TR><TD CLASS="quote">^^how's your wastegate?</TD></TR></TABLE>
not good. still open at idle. havent tried anything yet i need to know what that o ring thing is called. and which lines to hook up. white smoke comes out and **** at idle to rich u think? and my turbo laggggsss sooo bad. doesnt kick in till very high rpm's
Old 07-14-2004, 03:20 PM
Zakar's Avatar
hello kids.... The lesson for today is: don't beat on your car till its tuned properly
Old 07-14-2004, 04:20 PM
egturbo's Avatar
Default Re: (MusclecarGuyhasHonda)
oh and the inside of my car u can smell the exhuast makin me sick when ur wastegate was open at idle did u smell exhaust? im not gonna drive my car anymore.
Old 07-14-2004, 04:26 PM
B18EG6's Avatar
Default Re: (egturbo)
are you sure the (excuse me... i dont know the name of this part) 'valve' is closed at idle? The little exhaust valve looking thing with a long stem on it, it connects to the membrane via 2 or 4 set screws and if these get lose the membrane cant grip the valve stem, and it will be too far open. mine was
Modified by B18EG6 at 8:40 PM 7/14/2004
Old 07-14-2004, 04:54 PM
Sunrise City Rider's Avatar
Default Re: (B18EG6)
You need that ring to seal the wastegate from flowing exhaust past the valve...You do not need a gasket and I actually recommend running without a gasket...Use a Gasket for your dumptube and click the Vent from Outside Air to Recirculating Inside Cabin Air to keep the exhaust gases out...
Old 07-14-2004, 05:09 PM
egturbo's Avatar
Default Re: (Sunrise City Rider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sunrise City Rider &raquo;</TD></TR><TR><TD CLASS="quote">You need that ring to seal the wastegate from flowing exhaust past the valve...You do not need a gasket and I actually recommend running without a gasket...Use a Gasket for your dumptube and click the Vent from Outside Air to Recirculating Inside Cabin Air to keep the exhaust gases out...</TD></TR></TABLE>
yep not using gaskets. whats killing me is the stupid thing being open at idle. makin me very sick. i gotta fix this problem. i have the side of the wastegate hooked up to the nipple on the turbo.
Quick Reply: my wastegate stays open at idle :(
