>>>This is why you don't stretch tires!!<<<
Old 02-13-2011, 12:21 AM
  #51
Slain's Avatar
Default Re: >>>This is why you don't stretch tires!!<<<
I had seen this happen on the fwy at about 70 mph ek hatch took a instant dive towards the grassy divider. Stopped to see if they were ok and saw the culprit stretched tires that were busting at the seams
Old 02-14-2011, 03:00 PM
  #52
9d8gsr's Avatar
hellastretched!! lol.
Old 03-15-2011, 09:50 AM
  #53
em2_attic =b's Avatar
keep the air pressure up, make sure they are beaded properly and you will be ok if not then yeah they will pop..
Old 03-15-2011, 09:55 AM
  #54
PatrickGSR94's Avatar
yeah that sounds like a great suggestion
Old 03-15-2011, 01:16 PM
  #55
Sanji
toyomatt84's Avatar
Almost like a heroine addict stating that heroine is good for you.
Old 03-15-2011, 03:04 PM
  #56
Spitfire8o5's Avatar
but how are people gunna look hellafush x50 with the proper tire sizes?!?!?! lol
Stretch'd Tires FTL!
Old 03-16-2011, 12:28 AM
  #57
LoLoCivic's Avatar
well thats why when you stretch a tire at a tire shop they mkae u sign a paper and plus i heard stretch brand of tires are key too
Old 03-16-2011, 01:15 PM
  #58
Sanji
toyomatt84's Avatar
Huh? I don't know what you're referring to with a "stretch brand of tires". There's nothing I've ever seen on the market that comes close to that.
Old 03-16-2011, 03:39 PM
  #59
freeagent's Avatar
lolz i hate streched tires,
function over form all day!
and i work at discount tire, there is no such thing as stretch brand tires,
and keeping them properly inflated and rotated will not help
and really beaded properly????????
like wtf how can you even type that?
how can a tire be installed properly without seating the bead? even on a streched tire theres no way to install it properly(if stretched tires could be counted as proper) without seating the bead,
sorry long day at work lol
Old 03-16-2011, 04:08 PM
  #60
ThatDudeRich's Avatar
I agree!!!
Old 03-21-2011, 02:26 AM
  #61
EK.KEV's Avatar
ouch
even though i like how it looks id never do it to my car!
Old 03-21-2011, 06:55 AM
  #62
BobbyRodriguez's Avatar
Would a 195/45/15 be a stretch on a 15x7,or 7.5?
And if the 195 is a stretch ,then would a 205 be also?
Old 03-21-2011, 06:58 AM
  #63
Cooper The Tire Rack's Avatar
It would not be a stretch.
Old 03-21-2011, 07:17 AM
  #64
The tire manufacturer will list the approved wheel widths for that size tire.
7" would probably be borderline, 7.5" would probably be a stretch.
Old 03-21-2011, 12:35 PM
  #65
Well you tell me , because one person say's not a stretch ,other person say's it's a stretch . And the company is telling me in the info of tire size that will fit , that even the 15x8 version will fit a 195.
Old 03-21-2011, 12:49 PM
  #66
TunerN00b's Avatar
"A 195" is a terrible way to discuss tires.
Different sizes of "195" will be approved for different wheel widths. A 195/50-15 could very well be approved for different widths than a 195/55-15 or a 195/45-15.
Just go off of what the manufacturer has listed as the approved size for the exact tire you wish to use.
The only tire I can find (quick search) in that size is the Yokohama S.Drive, which is approved for wheels 6" - 7.5" wide, according to Yokohama's website. If you're looking at a different tire, check with the manufacturer on approved sizes before buying.
Old 03-21-2011, 04:03 PM
  #67
Ok so your telling me the side wall size matters on the fitment of width?
Old 03-21-2011, 05:23 PM
  #68
TunerN00b's Avatar
On a more serious note, of course the aspect ratio and/or wheel diameter can change the wheel width fitment, given the same section width.
You need to look up what wheel sizes are approved for the exact model and size of tire you intend to use.
A common example, a 205/45-16 is usually approved for wheels 6.5" - 7.5" wide, but most 205/40-16s are approved for wheels 7.0" - 8.0" wide.
The first number in a tire size is the section width, not the tread width, and not the width at the bead. All it tells you is the widest part of the sidewall, which isn't even a very useful piece of information.
Old 03-21-2011, 07:02 PM
  #69
freeagent's Avatar
agreed^^^^^^
Old 03-21-2012, 12:24 AM
  #70
senor honda's Avatar
Default What am I seeing?
The stretched tires that i see in Florida have the tire bead about 1/2"
from the rim lip.
Why do all these pics of destroyed tires show the tire bead up against the
lip of the rim?
Near the front, that red car looks more like the wheel/tire are too wide
and rubbing inside the fender more than it looks like the tire bead is not
touching the lip of the rim. What am I missing seeing?-Bob
Old 03-22-2012, 08:35 AM
  #71
jmai86's Avatar
I used to daily drive a 195/45 on a 15x9 for year or so without any issues. It wasn't too crazy looking. Any more of a stretch than that though is just asking for trouble.
It's an aesthetic thing.
Old 03-22-2012, 10:02 PM
  #72
KenM710's Avatar
Aesthetically, I see why this is done...but I just can't see from a safety stand point how someone can DD a car knowing the risks are multiplied.
Old 03-25-2012, 08:17 AM
  #73
little rookie's Avatar
And i dont think its the tire stretch that eats the side wall apart like that, it all the guys that run crazy camber, trying to get a 10 inch wheel with zero offset under thier civics fenders.
Old 03-25-2012, 10:12 AM
  #74
Sanji
toyomatt84's Avatar
Stretching a tire causes undue stress to the sidewall directly. As the vehicle rolls it puts a lot of strain on the sidewall indirectly, which causes a lot of heat build-up and can cause the belts to separate from the rubber and just disintegrate. Your opinions aside, that's the actual cause of a lot of the problems stretched tire drivers experience when driving longer distances.
Old 03-26-2012, 07:37 AM
  #75
FlewByU352's Avatar
Originally Posted by SikEj8
I am not a fan of the super stretch but I have semi stretched tires on my coupe, I have not ran into any problems but he main thing is people need to remember not to drop mario andretti speed runs on stretched tires.
Then you are willing to drive boring and never have any fun. Function > Form
Quick Reply: >>>This is why you don't stretch tires!!<<<
