Summer tires for EM1 16" wheels
Old 07-22-2016, 12:21 PM
bspeed's Avatar
Default Summer tires for EM1 16" wheels
EM1 running Apex'I N1 Pro 99+ spec lowered ~1.5"
I am running 16"x7 RE30 wheels to fit my brake kit, looking for some advice on summer tires.
15's are way easy.
Currently running All season Toyo Proxes 4 205/45r16, soft sidewalls make for a gummy turn in.
Want: an improved grip, better than current turn-in, fits wheel well.
Don't want: spend a grand on tires, get greasy during spirited driving.
Don't care: road noise, brand
Car is occasionally used to drive to work, mostly just cruising up and down mountain passes with friends, maybe a HPDE at Fontana one day.
Old 07-23-2016, 05:41 AM
H-T Platinum Sponsor
Turk@TireRack's Avatar
Default Re: Summer tires for EM1 16" wheels
With the 205/45-16, I would recommend you look at the Bridgestone Potenza RE-71R for best in class grip and steering response. They are a bit on the pricier side though, so if you wanted to save a couple bucks and still have improved grip and steering response over your current tires, you would probably like the the new Firestone Firehawk Indy 500.
__________________
<a href=mailto:turk@tirerack.com>turk@tirerack.com</a>
1.800.428.8355 ext 4065
Turk | Tire Rack
7101 Vorden Parkway
South Bend, IN 46628
Old 07-23-2016, 01:50 PM
bspeed's Avatar
Grassroots drooled over those Potenzas, but they are out of my budget for my purpose. The Firehawks look like a nice alternative.
Old 07-25-2016, 07:30 PM
Sprockets's Avatar
Other than price, how do the Firehawk Indy 500 tires compare to these:
Bridgestone Potenza RE760 Sport
Old 07-27-2016, 08:17 AM
The Firestone Firehawk Indy 500 is actually the replacement tire for the Bridgestone Potenza RE760 Sport, so they are an improvement.
If you didn't know, Firestone is actually owned by Bridgestone, so that's why they are able to do this.
__________________
Turk | Tire Rack
7101 Vorden Parkway
Old 07-27-2016, 08:55 AM
On vacation
testify's Avatar
The Kumho V720 is a better choice for the money than the RE71Rs.
The difference in performance between all of the hot summer rubber is nearly immeasurable except in the most controlled environments, and the V720 are really inexpensive.
Old 07-27-2016, 10:11 AM
The V720 is certainly a very good tire for the money, and a fantastic option for autocross, but they are not recommended for extended runs or extreme heat situations like the OP's use for HPDE, road racing, or long mountain road attacks at high speeds. The reason for this is, in the more extreme heat and long running situations, they have a tendency to wear out the center rib and it can even start peeling away. This causes a loss of grip and a lot of noise, and in extreme cases can even cause the tire to fail.
The other problem there is that he was looking at 205/45-16, and the Kumho Ecsta V720 doesn't come in that size. The only 16" size I see that tire in is 225/50-16 and those are an inch wider and about an inch and a half taller than he was looking for, I believe.
__________________
Turk | Tire Rack
7101 Vorden Parkway
Old 07-27-2016, 01:15 PM
Sprockets's Avatar
It's good to hear confirmation of that. I did some searching last night and found out that the RE760 is RE001 in other countries, and the Indy 500 is Bridgestone's RE003. I hope they don't raise the price on the Firestone, because it's a bargain. I missed out on a $60 rebate in the Spring. My RE760 tires still have plenty of tread left, but I'll be getting the Firestones when it's time to replace them, thank you!
Old 07-27-2016, 01:59 PM
On vacation
testify's Avatar
I've read about the chunking.
I have a set of 235/45/17 and 245/40/17 V720s, and after a few trackdays on a heavy AWD car, I've still not experienced the issue.
Might be because I wasn't foolish enough to try to run them at full tread, though. I've seen chunking from all sorts of different tires when theyre abused at full tread.
Old 07-28-2016, 04:07 AM
Might be because I wasn't foolish enough to try to run them at full tread, though. I've seen chunking from all sorts of different tires when they're abused at full tread.
It's good to hear that not everyone racing on these is experiencing that! Running them at reduced/shaved tread depth is definitely a good idea to help avoid having that problem, too.
__________________
Turk | Tire Rack
7101 Vorden Parkway
Old 07-29-2016, 04:43 PM
bspeed's Avatar
I had some RE760's before and enjoyed them a lot. Firehawks it is.
K2e2vin
11-16-2008 12:36 PM
Xymox007
10-13-2004 07:39 AM
TedR719
08-05-2004 05:57 PM
TedR719
07-20-2004 06:42 PM
rltrock
07-23-2001 11:21 AM
Quick Reply: Summer tires for EM1 16" wheels
