15x8 or 7 (?) offset wheels on 91 civic
Old 06-15-2010, 11:31 AM
run for cover's Avatar
Default 15x8 or 7 (?) offset wheels on 91 civic
I am planning on picking up a set of rims for my 1991 civic. The rims can either come in 15x7 or 15x8 .. and Specialized offsets ranging from "0" upto "+48"
I am picking up a set of coil overs for the civic as well.
My question is...What is the best rim and tire size to go with? I really want to slam the car.
These are the wheels that I want to go with.
XXR 522
http://www.xxrwheels.com/xxr_522_16.shtml#
Thanks
Old 06-15-2010, 11:34 AM
TunerN00b's Avatar
Default Re: 15x8 or 7 (?) offset wheels on 91 civic
15x7 and 195/50-15
For offset, you'll want to measure on your car, at your desired ride height and camber (if adjustable), to get it as flush as you'd like it.
Old 06-15-2010, 12:15 PM
H-T Order of Merit
nsxtasy's Avatar
Originally Posted by TunerN00b
15x7 and 195/50-15
Old 06-20-2010, 07:34 PM
LowFlyin''s Avatar
If you are wanting to slam it, the wheel and tire size suggested above is good, and I'd go further to suggest a wheel with +41mm - +43mm offset.
Hint: You'll get a little more inner clearance if you'll run DA front knuckles...and you'll gain a hair more negative camber, too.
Old 06-28-2010, 02:36 PM
planning on slamming the car.
Old 07-03-2010, 12:55 PM
Black R's Avatar
i like agressive, so I'd suggest 15x8 in +24 offset on 225/45/15. *(this gives you the exact same backspacing as oem, so no inner clearance issues).
You can go with a 225/50/15 if you want a little taller sidewall.
Old 08-26-2010, 07:41 PM
a +15 offset. what tires?
b20vtecGSR
07-05-2017 10:54 PM
official_del-sol
02-10-2015 07:50 PM
pxlds
08-25-2014 09:24 PM
TravisBiggie
05-08-2014 05:01 PM
WannaRun??
07-14-2012 08:20 PM
Quick Reply: 15x8 or 7 (?) offset wheels on 91 civic
