Welding stainless with Co2 gas
Old 10-31-2005, 05:30 AM
Flashmn's Avatar
Default Welding stainless with Co2 gas
Ok, maybe you can answer me this what alot of people havent been able to.
What happens if I use CO2 as shielding gas when welding stainless steel?
Old 10-31-2005, 06:57 AM
OG Fabricator
weiRtech's Avatar
Default Re: Welding stainless with Co2 gas (Flashmn)
never used it, but i recommend argon for tig- or if you are doing mig try autoweld, i think it is a co2/argon mix that is cheaper than 100% argon.
Old 10-31-2005, 08:59 AM
beepy's Avatar
Default Re: Welding stainless with Co2 gas (weirRacing)
When using 100% argon with stainless, I get a high crown that appears to be from a "cold" weld. When using 75%Ar/25%CO2, I get a hotter weld with better penetration. Based on that, I imagine 100%CO2 would create a weld so hot it would be impossible to avoid blowthrough. That's just a guess, though.
Old 10-31-2005, 09:10 AM
k24em2's Avatar
Default Re: Welding stainless with Co2 gas (beepy)
I'm assuming you are using a MIG welder, but the trimix seems to be the choice for SS and a MIG.
Old 10-31-2005, 10:15 AM
Flashmn's Avatar
Default Re: Welding stainless with Co2 gas (k24em2)
Yes, I know you're supposed to use trimix etc, but I'm just asking what would happen if I welded stainless with CO2.
...and yes its a MIG in question here.
Old 10-31-2005, 11:35 AM
fabrak8rX's Avatar
like beepy said - youll just get a cold weld, specifically with a mig set up, the same is not true of tig. some call it a "ropey" weld. generally poor penetration, it acts sort of like tinning if you know what i mean, it just dosent flow.
it isnt that it dosent work at all, its just on the low low end of functionality.
even if im just tacking up something, ill switch to the trimix. its a night and day difference to me.
Old 10-31-2005, 01:06 PM
Flashmn's Avatar
Default Re: Welding stainless with Co2 gas (fabrak8rX)
Hmmh, well I'm gonna try it this week and see what happens. Would cut down on gas costs if it works even "remotely" with CO2.
Old 10-31-2005, 03:44 PM
fabrak8rX's Avatar
sure give it a go - try a little more amps than usual for your material thinkness and go easy on the regulator pressure. it might get ya by.
andyvaj
Welding / Fabrication
09-02-2007 05:55 PM
Flashmn
12-26-2006 07:29 AM
yellowturbo
11
03-12-2005 10:00 PM
ivsihi
02-14-2005 07:52 AM
ExploitedRacing-HR
12-16-2004 03:17 AM
Quick Reply: Welding stainless with Co2 gas
