Don't hate, My car got totaled and I got bored....
Old 03-24-2008, 05:54 PM
B18CXr's Avatar
Default Don't hate, My car got totaled and I got bored....
Couple of quick notes:
* Anyone who says a firewall swap is "better" is flat out wrong, after you look closely at the EG A pillar base, you'll understand that it's strength lies within. Multiple layers of steel make up the door jam and windshield base.
* Re-alignment of the clip is easier than a FW swap.
* Electronics are easier with a clip swap.
* If your jigs are designed correctly, a clip chop is not a big deal.
* I had the car on the alignment rack before the cut then after the cut, I re-aligned it......the rear toe did not change.
* Company that installed the windshield said "This screen fits better than some new cars"
* ***** the haters, cost to fix the car with OEM LHD sheet metal and headlights was almost 1.4 times the cost of clipping it. Plus, GheyDM value-add for re-sell is a plus.
* ***** the haters.
* Will take many years to competently drive on track, at speed again....
* ***** the haters, was cheaper to fix this way.
* Over 80 hours in the job.
* Over 6 hours in the floor-board jig alone.
I decided to make the cut under the front seat mounts to aid against horizontal shear
Note: floorboard jig
Rattle can ownz all
Vertical plates were added to aid against vertical shear
Modified by B18CXr at 11:13 PM 3/24/2008
Old 03-24-2008, 06:33 PM
Pockets's Avatar
Looks like a job well done. I like your jig. Did you sleeve it at all? I think the hardest part clipping was getting the rocker/pillar sleeves to evenly slide in without getting jammed up somewhere.
Old 03-24-2008, 06:42 PM
B18CXr's Avatar
Default Re: (Pockets)
yes, all 2-D planes were internally sleeved.
Old 03-24-2008, 06:51 PM
ShawnR's Avatar
Default Re: (B18CXr)
looks good more pics!
Old 03-24-2008, 08:33 PM
Sanji
toyomatt84's Avatar
With the jigs already made, I suppose you could probably do multiple swaps with this method. for being precise.
Old 03-24-2008, 11:38 PM
91jdmhatchback's Avatar
Default Re: (toyomatt84)
damn that looks nice
Old 03-25-2008, 12:32 AM
140sx's Avatar
idk much about the chassis but isent there a seam that goes through there that you could have drilled outand over lap the material rather then just makeing the seam, dont get me wrong you did a nice job. The last rhd conversion that i did on a s13 I did the upper and lower firewall, then the seam over the tranny tunnel. Im thinking i might do it how you did next time on the seam across the whole car. but idk yet.
Old 03-25-2008, 12:43 AM
jzz30's Avatar
wow thats ballzy looks great though!
Old 03-25-2008, 05:20 AM
RS2 FAB's Avatar
Default Re: (jzz30)
dude..................stop what you're doing.
i got an idea.
cut the car in half again, take the back half, make a stand so it sits level........add beer keg mount in hatch area.
place plasma TV in front of half shell.........watch the game
Old 03-25-2008, 09:25 AM
TeamNextGenChris's Avatar
Default Re: Don't hate, My car got totaled and I got bored.... (B18CXr)
wow!i remember you talking to me about this last year,but didn't think you'd actually do it.love how precisely you did everything ..no "look at mah mad JDM conversion i did in mah basement" type ****.
will this be your track-only car,or also a daily?will you have it at Expo?catching you at your first RHD track-day would be my only chance in hell to ever roll you!and just remember-you'll have to use the right hand now to give the middle finger out the window.
as a testament that doing it right will present no problems,my coupe was rear clipped,and it's given me no problems for over ten years now.
Chris
Modified by TeamNextGenChris at 5:06 PM 3/25/2008
Old 03-25-2008, 11:59 AM
Man U FTW
Schister66's Avatar
Default Re: (91jdmhatchback)
Looks nice...at first glance, i was a bit skeptical, but it looks perfect in the end
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91jdmhatchback &raquo;</TD></TR><TR><TD CLASS="quote">damn that looks nice
Almost gives you an idea huh?? Hint Hint!!
Old 03-25-2008, 02:41 PM
LSEGHATCH's Avatar
Default Re: (Schister66)
Looks good as stated above, but why didn't you remove the paint where you tacked it together.
Old 03-25-2008, 03:02 PM
hootiehoo's Avatar
Default Re: (LSEGHATCH)
i would have also welded plates on the floor seams......
but i would not have had the skill or determination to do this at all
Old 03-25-2008, 03:12 PM
Bailhatch's Avatar
Default Re: (hootiehoo)
nice job
Old 03-25-2008, 04:40 PM
mx621's Avatar
Default Re: (Bailhatch)
very interesting.. will this car be caged at all. i would think that would be best.. just thinking out loud here.
Old 03-25-2008, 05:37 PM
B18CXr's Avatar
weldable primer
Old 03-25-2008, 10:33 PM
RS2 FAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">but why didn't you remove the paint where you tacked it together.
weldable primer</TD></TR></TABLE>
i was thinking about using that on my project car, was it hard starting an arc on that ****? i was sitting in the store reading all of the brand's cans LOL and i always though i would've been better off with grinding my old paint off, welding then hitting it with some cheap black primer
Old 03-25-2008, 11:09 PM
.john.'s Avatar
Default Re: (RS2 FAB)
if the cost to repair the car was so high, then why not get another shell?
Old 03-26-2008, 05:02 PM
B18CXr's Avatar
Default Re: (.john.)
never said it was "so high"
just like bare metal....zero issues
Old 03-26-2008, 06:24 PM
s800's Avatar
Very nicely done!
Old 03-26-2008, 11:37 PM
Chase's Avatar
Props, looks nice. I like the...what looks like, a bolt in jig. Makes for 0 worries of improper cutting/matching up. Good thinking.
Old 03-27-2008, 12:35 PM
reactone's Avatar
Default Re: (EF8kid)
Nice work, it must've taken quite a bit of patience to fab that floorboard jig. Very impressive.
Old 03-27-2008, 02:47 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .john. &raquo;</TD></TR><TR><TD CLASS="quote">if the cost to repair the car was so high, then why not get another shell?</TD></TR></TABLE>
try finding a straight rust free eg shell or complete on the east coast for less than $5000. I've pretty much given up on my car because shells are so hard to come by.
oh yea, yack =
Old 03-27-2008, 03:46 PM
B18CXr's Avatar
ditto
Old 03-27-2008, 04:51 PM
Default Re: (743power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">
oh yea, yack = </TD></TR></TABLE>
i've bought a couple in the past year for WAY less than that.just passed one up the other day for $1100.it's nice living somewhere that old men sell their commuter cars not knowing what they're worth
Chris
Quick Reply: Don't hate, My car got totaled and I got bored....
