D16 Crank Bolt? Help ASAP Pls
Old 01-07-2011, 07:55 AM
BobbyRodriguez's Avatar
Default D16 Crank Bolt? Help ASAP Pls
I recently lost a crank pulley , when driving, the bolt backed out from the recent water pump and timing belt replacement.
I bought an after market under drive pulley, the after market pulley will not fit the new bolt and washer that Honda makes. It will fit the bolt without the washer.
My question is how can i remove the washer with out damaging the threads.
Is there another Honda motor that will have a crank bolt with out a washer that will fit a d16 crank?
And Do i need the washer?
Its turning into a nightmare.
Do i need the crank pulley to drive the car, if it is off will the belt slip or come off? All i run on it is the altenator .
Thanks all
Old 01-07-2011, 08:30 AM
threes
c jackson's Avatar
Default Re: D16 Crank Bolt? Help ASAP Pls
what brand of aftermarket pully did you get?
Old 01-07-2011, 04:51 PM
black0hatch's Avatar
yes you need the crank pulley it drives the alternator. it also holds on the guide washer for the timing belt. why not just get another stock pulley and call it a day?
Old 01-08-2011, 05:44 AM
mikeymcm's Avatar
When the stock pulley came off did it damage the small slot for the key? I've seen a couple of motors come in with this problem.
Old 01-08-2011, 10:12 AM
To my surprise the crank threads or key hole did not get damaged just lost the pulley.
And my grandfather got the pulley bolt hole milled for me.
See
Old 01-08-2011, 11:31 PM
Westrock2000's Avatar
Glad it worked out....much better then cutting corners
newlude8657
05-03-2012 10:29 PM
socialistic
31
06-26-2011 12:54 PM
01celica_gts
07-15-2007 09:12 AM
model x
09-30-2006 09:38 PM
Milano97
06-02-2002 04:59 PM
Quick Reply: D16 Crank Bolt? Help ASAP Pls
