Brakes
Brakes
ISO big brake kit for 99 integra. Wondering if anyone is selling anything or if anyone has tried to piece together a wilwood kit with different components. Thanks in advance
Re: Brakes
I have the willwood hbdp one that bolt to the 10.2in rotors and integra or civic ex hubs.... they work just as good as the willwood dynalight versions that use a bigger rotor which makes u use larger rims... the direct replacment 4 piston calipers from willwood are worth the $400 for the pair. ... its tge cheapest option to get 4 piston calipers... work even better than the legend calipers swap... no headache.. just bolt .. bleed ... break in pads .. then go as fast as you want...
Re: Brakes
I'm more interested in the wilwood brake kit. I was going to do try a piece together a 6 piston kit or a 4 piston. All I would need is break pads, rotors, and calipers right?
c|rop3asy==[]
04-03-2011 09:24 AM
