tough shifting
tough shifting
i got my gsr transmission checked. i had to replace third gear and the clutch disk it had act clutch but i didnt replace the disk pressure thing that holds the clutch disk in (so it has oem clutch disk with act disk pressure thing.... the outside is yellow). so i got my transmission back and replaced all the things. Theres honda manual transmission fuild in there. now when i shift it is really hard to get it in gear. when the car is off it shifts through gears ok but not the best. because i know it could be better. The only thing i can think of is the clutch master cylinder because its leaking fluid or replace the act disk pressure to oem disk pressure, and/or something in my transmission. what do you guys think it is or what i should do?
Lordofdark176
17
12-04-2007 09:19 PM
