Transmission & Drivetrain Gearboxes, Differentials, Clutches
This slave cylinder has been out for a while
Old 06-30-2012, 08:44 AM
VTEC+Mini's Avatar
Default This slave cylinder has been out for a while
The Omni Power clutch master cylinder has been out for a while and it seems that some folks say it's not worth it.
But some others have said that it could actually damage the transmission or clutch.
I have manual 4 wheel disk brakes (4 pot Wilwood in the front), no boost at all so increased pedal pressure is really not much of a worry to me.
I'm also interested in a quick shifter..would appreciate the advice on if that is a good idea as well.
In case anyone is curious, the
the new ratios will be as follows:
1st........... 3.08
2nd............1.9
3rd............1.269
4th............0.966
5th............0.714
F/D............3.47
In case you're wondering why the ratios are so long....the car is a classic Mini by Mini-Tec and weighs 1700 lbs wet, has a JDM B18C Type-R and is now down at Go-Autoworks getting a Garrett GT28RS turbo system. The wheels are 13x7 shod with 195/45-13 tires. So longer ratios will really help. I just was wondering if a short clutch slave cylinder would be of any benefit or potentially cause some issues...like break expensive parts issues.
Thanks for your patience.
Old 07-01-2012, 10:24 PM
b16sir2000's Avatar
Default Re: This slave cylinder has been out for a while
Seems to be that it's going to be a trial and error thing. Start with what you ha e and if it doesnt work try that
Old 07-02-2012, 05:26 AM
Aquafina's Avatar
If you adjust your shifting it won't hurt anything. I tested one of the prototypes for Omnipower and loved it until the seal failed (issue has been corrected with the current units). I had the trans apart several times before, during and after the testing and it didn't cause any damage.
Old 07-02-2012, 06:43 AM
MR.johnson's Avatar
Anyone else running these with a twin disk?
Old 07-03-2012, 06:09 AM
Aquafina's Avatar
With an Action 1MD (HD single diaphragm) it was pretty stiff but easily driveable. Stop and go in interstate construction for 3 hours was the only time I didn't like it.
Old 07-03-2012, 02:15 PM
VTEC+Mini's Avatar
What kind of changes in my shifting are we talking about? I'm afraid I would give the "Stig" heart failure as it is.
Old 07-05-2012, 07:41 AM
Aquafina's Avatar
Hand/foot timing. Pedal will have less travel so you need to correct the actual shift with the hand to sync with the pedal. Just like a stock setup pedal should be fully depressed before you pull it out of gear and should be completely in gear before the pedal is released, otherwise wear will be accelerated.
gooblinn258
01-18-2014 05:02 PM
Civicfanatic_09
01-20-2010 08:58 PM
A08
08-31-2007 02:57 PM
siregcivic
10-16-2005 07:55 PM
WiLLMaTiX
11-08-2003 11:39 AM
Quick Reply: This slave cylinder has been out for a while
