gsr trans case broke need info
I just got a gsr trans and the case is broke where you bolt the t bracket at need to the speedo would it be safe to still run it with 2 bolts in it or switch the case since I have a spare ls case
Re: gsr trans case broke need info
Do I have to change the bearing and how do you shim it I have the case off a trans but never got to rebuild or change anything
JDMB20TDA
Transmission & Drivetrain
09-28-2008 09:19 AM
