Transmission & Drivetrain Gearboxes, Differentials, Clutches
B vs D series VSS (please help before I try)
Old 03-23-2009, 03:56 PM
HatchSpeeD's Avatar
Default B vs D series VSS (please help before I try)
Okay, I just ordered a VSS from someone here on H-T who claims it came out of a GSR.
As far as I know the B-series VSS speedo gear is metal & D-series is plastic & the gears aren't interchangeable but the sensors themselves are. I can't swap the speedo gear shaft out cuz I broke mine on accident.
I need to know before I try driving this thing if:
A) Some B-series VSS speedo gears are plastic
or
B) B-series & D-series are compatible & shouldn't have a problem.
I'm afraid to test this out without having more input from people other than the seller for fear of the speedo gear breaking off inside my transmission.
Here is a write up on another forum that causes doubt along with the fact that mine was metal as well. (the write up might not apply to all models)
http://hondaswap.com/general-tech-ma...es-vss-128865/
Old 03-23-2009, 04:27 PM
not so civic's Avatar
Location: gravity rides everything...everything will fall, se GA/ne FL
Default Re: B vs D series VSS (please help before I try)
yes some b series vss are one piece plastic units. and some d series will work. automatic d series speed sensors even will, but won't bolt in unless you trim a slot into the tip.
Old 03-23-2009, 04:34 PM
HatchSpeeD's Avatar
Thanks for the input...yea it's not so much the whole unit being plastic I'm concerned about it's the GEAR as shown in the link above.
Anyone else?
Old 03-23-2009, 04:38 PM
HatchSpeeD's Avatar
Yea I believe it was half plastic but again the speed gear was plastic not metal
Old 03-23-2009, 06:17 PM
HatchSpeeD's Avatar
Anyone else to chime in here?
Old 03-23-2009, 06:31 PM
D Tranny Guru
Mista Bone's Avatar
What are you exactly working on?
Old 03-23-2009, 06:33 PM
HatchSpeeD's Avatar
98 gsr transmission
Old 03-23-2009, 06:40 PM
i've never seen an issue with a broken plastic speedo pinion.
Old 03-23-2009, 06:48 PM
D Tranny Guru
Mista Bone's Avatar
other than it is broke and don't work.......
Old 03-23-2009, 06:51 PM
Originally Posted by HatchSpeeD
i wouldn't be worried about a perfectly good speed sensor with a plastic pinion breaking inside the tranny.
Old 03-23-2009, 08:29 PM
HatchSpeeD's Avatar
Well I counted the teeth & both had 20 & after talking to a few other people I said screw it & installed it. It worked...I guess only time will tell if the gears dont line up...
So IDK if not all B-series vss gears are metal or D-series work too but for now it works.
Old 03-23-2009, 08:36 PM
D Tranny Guru
Mista Bone's Avatar
Sorry about that, a tuner stopped by to help me on my car......
Old 03-23-2009, 09:26 PM
some pinion gears are metal some are plastic.
Old 03-23-2009, 10:12 PM
HatchSpeeD's Avatar
yea...it was noticebly smaller like shown in that link I put at the top...pretty much the same comparision but it works so I'll see how it pans out.
PARADOX_sf
04-16-2012 06:09 AM
mortificationrock
09-04-2008 02:23 PM
red_crx_89
03-04-2007 10:30 AM
demitrix
02-23-2006 09:10 AM
Quick Reply: B vs D series VSS (please help before I try)
