Transmission & Drivetrain Gearboxes, Differentials, Clutches
1995 Honda accord d4 light not working at all. And has no power in d4
Old 05-04-2016, 09:07 PM
VtecGang's Avatar
Default 1995 Honda accord d4 light not working at all. And has no power in d4
Was working fine but I took out the ECU fuse to reset cel after replacing vss. I lost the fuse but I tried replacing and it started doing this. I put in d4 to drive and it just revs but doesn't actually move. It automatic , I can drive by manually shifting but it starts smoking from transmission area. Need help ASAP . do i just get all new fuses ?
Old 03-10-2017, 09:14 PM
amerc's Avatar
Default Re: 1995 Honda accord d4 light not working at all. And has no power in d4
I assume all fuses are in place .... if you have smoke from the transmission .. this is serious .. could be no oil inside transmission ... and finally your transmission is toast. Check for leaks beneath your car ...... look for engine and transmission oil leakage. Have your transmission checked ASAP.
tuongtu3
06-22-2017 09:06 PM
psyce_raven
11-02-2009 04:49 AM
mcbeats
09-21-2009 10:50 PM
mrhondafrustration
09-15-2008 11:18 PM
Quick Reply: 1995 Honda accord d4 light not working at all. And has no power in d4
