valve spring rmeoval
how do i remove a valve spring without having to spend money on the vavle spring compressor tool, and how do u connect the retainer/take it off?
Re: valve spring rmeoval (importlegions)
You can remove a valve spring by taking sprk plug socket and put it over the center of the retainer. Then take a hammer and hit the socket. This will dislodge the keepers and the retainer will come off. Just be sure to be careful when doing this as you don't want the spring to come back at you. You will need the honda tool to put the head back together though. There is no way around that.
A valve spring compressor is going to make the job much easier.
Here you go: http://www.thetoolwarehouse.net/shop/SP-91400.html
It's even on sale...very much worth it IMO.
Re: valve spring rmeoval (Redline130)
mother! that would have been so much easier! we used a socket to remove all the stock R retainers/springs from my friends type-r and then used a c-clamp and cut the side out of a socket to re-install the portflow springs/retainers.. it got the job done but was kindof sketchy! :D
JDM_SOHC
03-23-2012 01:42 PM
Fezzie
12
08-21-2006 12:49 PM
Screamer
12-17-2003 04:41 PM
