Usdm gsr and Jdm gsr
I like to party
Re: Usdm gsr and Jdm gsr
God it's been awhile.
I think the JDM GSR may have different cams, but don't quote me on that.
No knock sensor on JDM motors.
Most JDM motors have different pistons that are higher compression, but I actually think the GSR may be the same.
They are pretty much the same thing.
Technical Hero
JDM B18C
SiR-G/GSRB18C1Edit
SiR-G/GSR
- VTEC
- Found in:
- 95-98 JDM Honda Integra SiR/SiR II (DB8, DC2)
- 98-99 JDM Honda Integra SiR-G (DB8, DC2)
- Identification: Black valve cover with dual runner intake manifold
- Red Line: 8200 rpm
- Rev-Limit: 8484 rpm- 8550 rpm (*For some only, most newer model SIR/SIR-G cut off at 8254 rpm)
- Power: 132.5 kW (180 PS; 178 bhp) @ 7200 rpm & 126 lb·ft (171 N·m) @ 6200 rpm
- Displacement: 1,797 cc (109.7 cu in)
- Compression: 10.6:1
- Bore: 81 mm (3.2 in)
- Stroke: 87.2 mm (3.4 in)
- ECU code: P72
- VTEC Engagement @ 4500 rpm
- Transmission Y80 (with optional LSD)
B18C1Edit
- DOHC VTEC
- Found in:1994–2001 USDM Integra GS-R (DC2)2dr (DB8)4dr
- Compression: 10.1.:1
- Rod Length: 140.0 mm (5.5 in)
- Rod/Stroke Ratio: 1.58
- Power: 170 hp (127 kW) @ 7600 rpm
- Torque: 128 lb·ft (174 N·m) @ 6200 rpm
- Redline: 8000 rpm (Fuel Cut-off @ 8200 rpm)
- Secondary Runners Open @ 4400 rpm
- VTEC Engagement @ 5800 rpm
Technical Hero
FFS Tech | B-series Piston Check
more than likely you can find minimal cam profile differences and prob a slightly more aggressive P72 ECU tune
VTECcnIT
02-13-2006 12:13 PM
