Unbaffled Oil Catch Cans ... Question
Old 02-06-2003, 04:17 PM
FritzInTN's Avatar
Default Unbaffled Oil Catch Cans ... Question
OK, Ive been looking into a catch can for my motor I'm building and ran into this link from CSpeedRacing
http://www.c-speedracing.com/howto/c...n/catchcan.php
However it says since the can was unbaffled they filled it full of steel wool. This seems like it would be a bad thing to have oxidized steel floating around. Any ideas? This seems counterproductive.
Old 02-06-2003, 04:22 PM
bruthaboost's Avatar
Default Re: Unbaffled Oil Catch Cans ... Question (FritzInTN)
Ifyou aren't comfy with steel wool, you can use copper wool. It's the mesh that traps the oil vapor.
Old 02-06-2003, 04:44 PM
kyle h.'s Avatar
Default Re: Unbaffled Oil Catch Cans ... Question (bruthaboost)
sees like a very easy concept to reproduce without the bling bling.
edit:
why is it located to far away? any advantage to having the lines being so long?
[Modified by kyle h., 1:46 AM 2/7/2003]
Old 02-06-2003, 05:08 PM
B18EG6's Avatar
Default Re: Unbaffled Oil Catch Cans ... Question (kyle h.)
Nope...just the only place they could mount it
Old 02-06-2003, 06:12 PM
altoid's Avatar
Default Re: Unbaffled Oil Catch Cans ... Question (B18EG6)
so two rubber lines one going from the pcv and one from the intake mani? and have them routed to a can full of steel wool, sounds like a 15 dollar job to me
Old 02-06-2003, 06:19 PM
IN VTEC's Avatar
I used the copper wool scours. A couple bucks for a pair at walmart.
[Modified by IN VTEC, 9:19 PM 2/6/2003]
Old 02-06-2003, 06:31 PM
Colin's Avatar
Default Re: Unbaffled Oil Catch Cans ... Question (EE4)
yup, its really easy to do for cheap. It can easily be done w/ a mason jar or something of the sort. It just won't look as good as this one.
Old 02-06-2003, 06:33 PM
altoid's Avatar
Default Re: Unbaffled Oil Catch Cans ... Question (91IntegGS)
function of fashion my friend. important words to live by, or the only thing that you'll have thats fast are the dollars leaving your wallet
Old 02-06-2003, 06:34 PM
ChiBoy's Avatar
The steelwool won't oxidize because it will be soaked in the oil that it traps. Should't rust any faster than your crankshaft.
Old 02-06-2003, 06:42 PM
Colin's Avatar
to each his own (don't worry, i'm not an all show / no go type guy). I just personally prefer things that look a little more professional than a mason jar zip tied to the frame rail. But I don't think i'd fork out the big bucks for that one in the picture either.
Old 02-06-2003, 07:11 PM
keebler65's Avatar
i remember reading a couple of different places that the idea place to mount it is anywhere thats LOWER than where it comes out the back of the block (at the pcv valve). that might have something to do with it, seeming how low they put it.
Old 02-06-2003, 07:58 PM
tinkerbell's Avatar
Default Re: Unbaffled Oil Catch Cans ... Question (keebler65)
that sounds wrong... where did you hear that? the block outlet is usually way lower than the PCV valve
my catch can is mounted higher than the block outlet with the PCV valve ontop.
see link in sig.
t..
EFinSi
02-12-2008 08:20 AM
FlySi
09-06-2004 10:31 PM
VTECAcuraGSR
10
07-12-2004 01:26 PM
RRRex
09-30-2003 10:59 AM
Tommy_Gunns
08-13-2002 03:40 PM
Quick Reply: Unbaffled Oil Catch Cans ... Question
