quick question about wd-40 mixing with oil
Old 11-23-2010, 11:09 AM
v8killaz's Avatar
Default quick question about wd-40 mixing with oil
i recently installed a rebuilt head and cams and what not on my block. well i used wd-40 to clean misc parts like the cam holders and caps. i am worried because the wd-40 mixing with the oil.
can i start the car with the wd-40 mixed with the oil or should i flush it out and change the oil. i will be changing the oil about 5 miles after letting everything set in.
any ideas. about 2oz of wd-40 prob went in or less.
Old 11-24-2010, 06:01 AM
I'm not Rick!
rick_rabies's Avatar
Default Re: quick question about wd-40 mixing with oil
2oz...........i wouldnt worry about it.
Old 11-24-2010, 10:34 AM
Wheres my titleeeee!
nemisish20's Avatar
I would just crank the car up for about 5 seconds and then drain the oil and start fresh.
WD-40 is less dense than oil so it will do the same thing as having water in the oil. It will rise to the surface and cause aeration and sludge.
2 OZ. is alot more than you would think.
Old 11-24-2010, 01:06 PM
v8killaz's Avatar
thats what i was thinking. but would starting it for a quick 10 seconds do much harm after priming the oil pump
Old 11-24-2010, 01:48 PM
slobalt77's Avatar
we lube all the fuel lines, spray down all the cylinders via the spark plug holes, and then push the car to turn it over. ( Sprint car. 350 SBC ) after every race, and use. WD-will not hurt getting into the engine.
Old 11-24-2010, 03:55 PM
I'm not Rick!
Wd-40 is flamable like brake cleanr. Water is a dif story
Old 11-24-2010, 04:09 PM
v8killaz's Avatar
well i started it for 10 seconds and shut it down. will change the oil later. not going to drive with engine assembly lube, reg oil, and wd-40 all in my engine.
Old 11-24-2010, 10:00 PM
nemisish20's Avatar
Generally you would change the oil after a rebuild anyways.
I constantly get accusumps back for rebuilds and people have them full of assembly lube and etc. Then they call and ask why the engine went right after an engine build and we usually tell them ask your builder but also you had about 2 qts of assembly lube in the system.
Old 11-26-2010, 11:05 PM
Scott_Tucker's Avatar
It absolutely doesn't matter if you've got that small of an amount in there.
Old 11-27-2010, 11:10 AM
v8killaz's Avatar
yeah it was a head rebuild and we just wanted everything to run good, and when it turned over i shut it off after 10 seconds and changed the oil yesterday
Flux
07-13-2006 08:48 AM
speedymon
11-29-2004 05:28 PM
CRXstress
09-27-2004 10:01 PM
tha Big EZ
07-02-2003 08:40 AM
(__________)
04-10-2003 04:07 PM
Quick Reply: quick question about wd-40 mixing with oil
