Problem please help ???? humming noise
ok my 97 gsr is doing something weird when i am driving and i go to take a turn left or right i get this weird humming noise but it kinda sounds like road noise but im thinkin it might be the hub bearings its like a wuwuwuwuwwuwuwuwuwwuwuwuwuwuwuwu when im going around a turn
so maybe someone can help me out with my problem
Re: Problem please help ???? humming noise (DeDonDeRosa)
Also, hub bearing noise will usually be the bearing on the side opposite the turn. That is, the right side bearing will usually make the noise when you're turning left, and vice versa. Also , usually, one bearing will go before the other one does. It's UN-usual that they'll both go at once. Possible, certainly, but unusual.
kenskii
07-08-2014 08:33 PM
