Is it possible to bend valves turning crank by hand?
Old 04-20-2005, 06:30 PM
Chubz's Avatar
Default Is it possible to bend valves turning crank by hand?
im changing my timing belt and i just want to know is it possible to bend valves by turning the crank by hand, it felt as if the pistons hit the valves at one point and wouldnt turn , but then it did?
Old 04-20-2005, 07:01 PM
Runnerdown's Avatar
Default Re: Is it possible to bend valves turning crank by hand? (Chubzilla)
Yes! It is possible I know someone that did that before. I Always take the crank off tdc a bit and line the cams up first. Perhaps you are mistaken for valve spring tension?
Old 04-20-2005, 09:10 PM
HEAD's Avatar
Default Re: Is it possible to bend valves turning crank by hand? (Runnerdown)
If you look like the Incredible Hulk...you can bend anything.
Virgle DeBord
04-15-2018 02:44 PM
terronb20ek
16
12-06-2010 01:00 AM
djhatchtraxxx89
10-04-2006 03:46 PM
94eg!
22
05-08-2006 08:07 AM
97ex+zex
02-04-2003 01:45 PM
Quick Reply: Is it possible to bend valves turning crank by hand?
