P28 Datalogging.... possible through DLC Connector with stock chip?
Old 08-15-2006, 07:48 PM
tekcivic's Avatar
Default P28 Datalogging.... possible through DLC Connector with stock chip?
Hoping someone can help answer a question for me.
I have a stock p28 honda obd1 ecu. I'm wanting to do a bit of datalogging before actually chipping the ecu and purchasing a rom burner. Does anyone know if it is possible to datalog with a stock chip using the dlc connector? I saw a small post about the connector on PGMFI.ORG but it doesnt say much. Anyone have any experience with this?
Thanks
Tek
Old 08-15-2006, 11:09 PM
HT Order of Merit
JDM_Ej's Avatar
Default Re: P28 Datalogging.... possible through DLC Connector with stock chip? (tekcivic)
In theory, yes, but with Crome at least, you have to load datalogging software onto the ROM so it can read the information... so you will probably need to chip it first.
Old 08-16-2006, 01:58 AM
mtber's Avatar
Default Re: P28 Datalogging.... possible through DLC Connector with stock chip? (JDM_Ej)
No it is not. You need to have quick datalogger + rtp plugins on the eprom you are running in order for crome's datalogging features to work.
You also need to remove rp12 on the ecu.
Old 08-17-2006, 03:19 AM
HT Order of Merit
JDM_Ej's Avatar
Default Re: P28 Datalogging.... possible through DLC Connector with stock chip? (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">No it is not. You need to have quick datalogger + rtp plugins on the eprom you are running in order for crome's datalogging features to work.
You also need to remove rp12 on the ecu.</TD></TR></TABLE>
You mean J12? I thought that was only required for Uberdata?
gsrhatch95
08-30-2007 06:17 PM
dizzyroc88
10
03-22-2007 05:32 PM
tekcivic
08-17-2006 07:58 AM
B16aSir2
01-22-2006 06:28 PM
HOND PWR
07-22-2003 05:44 AM
Quick Reply: P28 Datalogging.... possible through DLC Connector with stock chip?
