Oversized pistons, what in MM does .xx mean??
Old 01-21-2002, 08:39 PM
B18C-EJ1
Guest
Posts: n/a
Default Oversized pistons, what in MM does .xx mean??
I'm trying to get the exact size of my pistons.
So what is each one in mm?
10 over?
20 over?
25 over?
You get the idea. Is there a formula I could use?
Thanks
Old 01-21-2002, 08:51 PM
earl's Avatar
Default Re: Oversized pistons, what in MM does .xx mean?? (B18C-EJ1)
1 mm = .03939 inches
10 over = .010 inches larger
81 mm x .03939 = 3.19059 diameter in inches
Old 01-21-2002, 09:15 PM
vhd
vhd's Avatar
you can also use this formula to change mm to inches or vice versa
X (mm) divided by 25.4 = X (in inches).....i.e. 81.5mm divided by 25.4 = 3.209"
or
X (inches) times 25.4 = X (in mm).......i.e. 3.209" times 25.4 = 81.5mm
Old 01-21-2002, 09:45 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Oversized pistons, what in MM does .xx mean?? (vhd)
So, If I used 25 over pistons, they are 81.64mm?
Is that right?
81mm = 3.189
25over = 3.214
3.214= 81.64mm
I'm rounding to .xx digits.
Old 01-21-2002, 10:00 PM
sgT
sgT's Avatar
Most people that refer to 25 over mean .25mm overbore.
Old 01-21-2002, 11:44 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Oversized pistons, what in MM does .xx mean?? (sgT)
So that would make it 81.25mm?
Old 01-22-2002, 09:17 PM
vhd
vhd's Avatar
you had it right, your bore would be 3.214" or 81.63mm with the .025"/.635mm over
Old 01-22-2002, 09:48 PM
earl's Avatar
Simply stated, .5 mm overbore equals .020 inches overbore
honda_ef9
03-22-2007 03:49 PM
Dent Free
06-14-2004 02:29 PM
mz3bo
04-27-2003 10:15 PM
Benny Z
12-20-2002 03:35 AM
JDMvtecDRAGSTA
07-02-2002 01:17 AM
Quick Reply: Oversized pistons, what in MM does .xx mean??
