lsvtec-b16 head, how do i take out the larger plug for the oil feed???
Old 10-22-2005, 09:42 PM
blackeg's Avatar
Default lsvtec-b16 head, how do i take out the larger plug for the oil feed???
the larger plug, intake side of the head right behind the distributor. its the one with the allen. whats the best way to take it off. i had the allen wrench in there with about a 1ft pipe over the end of it. it kinda felt like it was gonna start to strip the plug, so i stopped? what do u guys think? just get a allen socket and use an air wratchet???
Old 10-23-2005, 06:27 AM
bruthaboost's Avatar
Default Re: lsvtec-b16 head, how do i take out the larger plug for the oil feed??? (blackeg)
I just used the allen with plenty of lot's of penetrating lube (left it over night). If you strip it, no biggie. Just drill it to use an extractor.
HTH
Old 10-23-2005, 06:38 AM
blackeg's Avatar
Default Re: lsvtec-b16 head, how do i take out the larger plug for the oil feed??? (bruthaboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruthaboost &raquo;</TD></TR><TR><TD CLASS="quote">I just used the allen with plenty of lot's of penetrating lube (left it over night). If you strip it, no biggie. Just drill it to use an extractor.
HTH</TD></TR></TABLE>
true, didnt think about the pb blaster
Old 10-23-2005, 08:42 AM
blackeg's Avatar
ah nevermind i got it. used a breaker bar with a 8mm allen socket. just kept solid pressure on it while turning and it came out
Old 10-23-2005, 09:08 AM
non-VTEC's Avatar
some guys use a propane torch to lightly heat the plug up and it comes right out......
salaamq
12-28-2011 09:59 PM
SurferDude905
06-08-2009 07:23 PM
Cruzan77
05-10-2009 08:06 PM
Crx Jimmy
08-02-2008 08:07 AM
hatchback
06-29-2003 04:44 PM
Quick Reply: lsvtec-b16 head, how do i take out the larger plug for the oil feed???
