Bad ECU?
Old 07-18-2002, 07:08 AM
b16aeg's Avatar
Default Bad ECU?
I bought a skunk2 chipped p28 ecu and now vtec surges as it pulls.... It like cuts out intermittently.
The p30 ecu that was in before never did this.
It seems for sure that the ecu has a problem. but I was wondering if anyone else had ever had this problem or heard of anything like this???
Thanks
Old 07-18-2002, 10:07 PM
r7
r7's Avatar
Default Re: Bad ECU? (b16aeg)
dude, i have the same problem, and i have no idea how to fix it
i have the pr3 ecu, i've tried another pr3 aswell, and it still did the same thing.. so bad ecu = doubtful
let me know what you find out !!!!
Old 07-18-2002, 11:52 PM
Katman's Avatar
Thanks
i dont think its a bad ecu, more like a bad program--to eprom burn. If you had a stock chip im sure it would run like normal again.
Old 07-19-2002, 12:39 AM
r7
r7's Avatar
Default Re: Bad ECU? (Katman)
my ecu is stock.. same problem
Old 07-19-2002, 03:50 AM
b16aeg's Avatar
Default Re: Bad ECU? (r7)
I just think it has to be the ecu, since the stock p30 didn't have this problem. All my vtec wires have been checked for continuity and I've pulled the soleniod off to see if the screen inside could be clogged - But it looked fine. The engine has a good oil level and doesn't use or lose oil (so, the pressure switch should be give out the right signal)
It's not noticeable that it cuts out in first or second (I think because those gears go so quickly that there isn't time for it to studder or cut out)
What else could I check?
Old 07-19-2002, 08:44 AM
Katman's Avatar
like i said...
Possibly whoever chipped that ecu didn't have a good eprom burn or maybe something is loose and/or not completely soldered.
Old 07-19-2002, 03:08 PM
r7
r7's Avatar
i have the same problem, i've tried many things.. . even another ecu, and still the same
katman = from jdmhondaparts?
Old 07-21-2002, 07:58 PM
Katman's Avatar
yep, the one and only.
Old 07-21-2002, 08:48 PM
r7
r7's Avatar
cool nuff, do you know how to hexedit the .bin's for pr3 ecu?
have any info. that you can send me? or even some .bin's.. .
Old 07-22-2002, 12:33 AM
Katman's Avatar
i know how to edit vtec and redline points only, for the PR3 ecu. I don't really release any of my info or bin files to anyone, sorry.
Old 07-22-2002, 10:35 PM
r7
r7's Avatar
ok. well, can i email you something i found? maybe it's some use to you
Old 07-24-2002, 04:45 AM
b16aeg's Avatar
Default Re: Bad ECU? ***UPDATE***
Actually I think I may have figured the cause of the problem.
The ecu and vtec work fine - but only when driving very very mildly. So, I'm saying that if I drive down the road and I'm just cruising normal, and then decide to wind out a gear - the vtec will work perfect.
But... If I'm in vtec for a long period of time and I'm driving the car very hard the vtec will start to cut out more and more as I drive it harder and harder, until finally it throws a check light and I have no vtec at all.
Let the car sit for 20 mintues or so and go out and then drive normal, wind out a gear... vtec is fine, works perfect. Then start driving hard and it starts not working again (studdering and cutting out)
My belief is this, and I wanna see what anyone else has to say. I have a bad ecu, There obviously is something wrong with it. Do you think it could be getting to hot, because of driving hard? I don't mean hot like from the exhuast and the floor or the heater or anything.... I mean getting hot from working too hard almost like with an overclocked PC? I my opinion, its getting hot and then stops functioning properly.
Does this sould like it could be the problem?
vtec_lude
12-13-2006 07:25 PM
wrXtian
04-13-2003 04:29 PM
Quick Reply: Bad ECU?
