jumping rpm need heelllppppp!! gsr
I started my car today and i let it warm up a little then started driving. Now i stop at a light and tach is going up and down between 1500 -2000, car is stock with an intake. I need help to locate the problem, anybody?
Re: (david90)
it's probally not the coil, clean out your fast idle control valve on the bottem of the throttle body and it should go away, run a search for doing that for more info
Mad Scientist
Re: (Sideout)
check if coolant is full and bleed it just in case.if that dont work, check the iacv, and if that dont work take the fitv(if your car is obd1) out and shake it; if it rattles take it apart and screw the little white piece back in
hondaivi211
06-01-2005 05:25 PM
