How can you test INNER cv joints
Old 07-26-2006, 10:36 PM
JDM H22's Avatar
Default How can you test INNER cv joints
My Driveshaft shop axel had a bad OUTER cv joint that clicked really bad so I ordered a new outer joint from Driveshaft Shop. After racing at the track, on my way home I noticed the car would shake under throttle. I figured that joint **** the bed. So I replaced it. It still shakes under throttle. Something else let go. I am replacing the tie rod bushings, and not that I think it is this, but also the upper ball joints. I also will check the rear motor mount since I havent check that one yet. It seems to me that it is drivetrain though. The only thing left is those inner joints. I dont want to replace them till I know they are bad, so is there any way to check or know if they are bad. thanks
Old 07-27-2006, 10:49 AM
thesmogman's Avatar
Default Re: How can you test INNER cv joints (JDM H22)
Just grab it and move sideways if it has play it is shifting side to side and becoming unbalanced. Did you loose any wheel weights, something else to check
Also check for flat spots or a bubble on the tire.
Old 07-27-2006, 10:53 AM
JDM H22's Avatar
Default Re: How can you test INNER cv joints (thesmogman)
can I bang it back into place better?
Old 07-28-2006, 08:16 AM
JDM H22's Avatar
bump
Old 07-28-2006, 02:44 PM
rmcdaniels's Avatar
I just pull mine off, disassemble them, clean them up and inspect them. You'll nees a $10 banding tool and some $1 bands to seal the boots back up, plus a pack of CV joint grease.
Old 08-03-2006, 10:02 PM
slowcivic2k's Avatar
Default Re: How can you test INNER cv joints (rmcdaniels)
you cant really test the joint, but pull it apart like he said, check the toroids for torqueing, and make sure all the needles are there and not bent, check the splines for torqueing as well, also the inner joint splines. inspect the inboard shaft end for dents on the inside, and excessive wear, the joint should have very little play up and down, but plenty side to side.
ragnarok0mega
07-11-2009 08:51 PM
Dwight Schrute
Suspension & Brakes
08-26-2006 11:15 AM
JDM H22
07-28-2006 09:04 AM
JDM H22
07-28-2006 08:16 AM
JDM H22
Suspension & Brakes
07-27-2006 11:58 AM
Quick Reply: How can you test INNER cv joints
