D15Z1 head on a D16y7 motor YES or NO
Old 04-19-2003, 06:21 PM
SCsol's Avatar
Default D15Z1 head on a D16y7 motor YES or NO
Will a D15Z1 head (1.5 sohc vtec) work with a D16y7 motor for a mini-me swap?
If so what will i need?
Is this head D15Z1 the same or close to a Z6 or a Y8 head?
Any help would be great. Thanks
Old 04-19-2003, 06:32 PM
orange.honda's Avatar
Default Re: D15Z1 head on a D16y7 motor YES or NO (SCsol)
it will work. but i dont know why you would do that. it has vtec-e not vtec-p. that means it is very economical. not the best to sup up. but if you run another cam and tune the vtec then yea it should be better. i would save your cash and buy a y8 or z6 head it is worth the cash.
Old 04-19-2003, 06:36 PM
SCsol's Avatar
Default Re: D15Z1 head on a D16y7 motor YES or NO (orange.honda)
Well its going in my GF car. So HP is not a big deal!!!! But i do have the VX motor with the head in the car now but its burning oil pretty good. And I also have a D16y7 motor to be put in it. I just dont feel like finding another ECU so it would almost be just as easy to do the swap.
What parts do i need? And does any one know the final C/R from the motor. Is there a C/R chart to look at for these motor swaps?
Thanks any help would be great
Old 04-19-2003, 06:42 PM
http://www.knology.net/~jediklc/D.htm
thats the best i can do. but it doesn't have the combo you want.
Old 04-19-2003, 06:44 PM
SCsol's Avatar
does any one know the cc'svolume of the Z1 head compared to the cc's volume of the Z6 or the y8 head? Any help would be great so i can use it with orange.honda's chart he was nice enough to find me.
Old 04-19-2003, 06:50 PM
SCsol's Avatar
does any one know the Piston Dome Displacement (cc per piston) for a
P2E-000 (USDM D16Y7) pistion
Old 04-19-2003, 06:51 PM
http://www.heeltoeauto.com/dseries/dseries1.html
this should help, i think
Old 04-19-2003, 06:53 PM
SCsol's Avatar
does this sound right
P2E 50.00 30.00 3.32 Dish a 3.32 cc dish for the pistions??
Old 04-19-2003, 06:59 PM
SCsol's Avatar
ok if the VX pistions have 7.05mm dish with a CR of 9.3to1
92-95 Civic VX D15Z1 1493cc
4 cyl, 16 valve
SOHC VTEC-E
9.3:1 c.r.
PGM-FI (MPFI)
using a 3.32mm dish woudint it make a CR of 10.657796861089744to1
How street able is this? what Hp do you think it will make?
And will i need to put APR studs in? (remmber its the GF's car) but i will use it to beat the freinds!!!!
Old 04-19-2003, 08:27 PM
SCsol's Avatar
What head bolts do i use? The Z1 or the Y7? Im using the Y8 head gasket. to get a CR of 10.47698067334861 to1!!!!
What cams can i put in this motor? Z6, Y8?? Will they work in this head?
What timing belt do i use?
Is 11to1 compression too much for daily driving on 89 oct gas?
Old 04-20-2003, 10:13 AM
SCsol's Avatar
Does some one know what parts to use? Please help if you know thanks
Old 04-20-2003, 12:09 PM
run the highest octane you u can 11:1 is pretty high but still streetable. out here in ca i can get 92 at arco. run at least 91. you shouldn't nneed after market studs or anything, but you should replace the head bolts with new ones.
Old 04-21-2003, 11:18 AM
SCsol's Avatar
Ok what about 10.6 to 1 with the timing around stock and driving it normal on the streets. Will i be Ok with 89 OCT gas??? OR is the 1.6 to 1 still too much? Is only a lillte more than a SI motor compression!!!
Tinoo
10
02-03-2011 04:55 PM
Cras-Delsol
15
09-19-2008 09:39 PM
joebobkabila
07-04-2003 08:56 PM
civic dx
02-23-2003 05:48 PM
Quick Reply: D15Z1 head on a D16y7 motor YES or NO
