CRV camber kits? Are there any!!
Which camber kit can I use for my 98 CRV? I'm wondering if the accord camber kit would work?I have a really bad camber problem in the rear or my car. Must be from the weight of the system cause even when I adjust the coilovers on my crv it does nothing for the camber.
Re: CRV camber kits? Are there any!! (advanracing62)
I'm sorry but whatcha mean by shim out the rear? can you please explain
Re: CRV camber kits? Are there any!! (roydogg)
yeah, you go to HD and get some longer bolts, can't remember what diam. and length. Then you pick up some washers usually 4 or 6 per side. You take the bolts out of the upper rear arm that go into the body, install the washers, throw the bolts in with a little thread lock. Presto! instant alignment for 6$
