Common Honda Bolt thread pitch size dimension
#176
Re: Common Honda Bolt thread pitch size dimension
Looking for a few M6 (10mm) nuts.
Where all can I usually find them on a Honda.
I got a parts car Civic sitting around.
No motor, so valve cover nuts are out.
Any where else?
Any where else?
#180
Looks like I'm late to the party, but, I got one... What is the bolt spec for the Camshaft Position Sensor on 01-05 Civic? I seem to have dropped mine...into the LCA. Makes things a little tricky.
#182
I'm putting this in here cause it sees the most traffic, but it does pertain to civics, (as well as all hondas) I can't beileve there's not one of these threads already that's stickied.
Please help me fill in the blanks and or correct me if I'm wrong. Honda uses some weird sizes. I had to specially order a M14-1.5 nut for example. Also, do they all tend to share the same thread pitch? I see M12-1.25 and M12-1.5. I searched for "thread" and got 750 results, I'm not about to sort through 750 threads. I searched for "thread pitch" and it returned 97 results, most of them pertained to specific bolts
See this guys post:
https://honda-tech.com/zerothre...54427
M6-1.0 --- common (most of our 10mm head bolts)
M8-1.25 -- common (probably most of our 12mm head bolts)
M10-1.25 - some headbolts) (probably most of our 14mm head bolts)
M11-1.25 - freakshow timing belt tensioner on H/F engines. 7/16-20 is VERY close.
M11x1.5 -- some headbolts)
M12x1.0 -- flywheel bolts + shift fork ball spring bolts)
M12-1.25 - common (probably most of our 17mm head bolts)
M12-1.5 -- lugnuts)
M14-1.25 - crank bolt?)
M14-1.5 -- oil pan drain plug. 19mm head bolt that connects rear trans bracket to trans
M16-???
M20x1.0 -- 10mm allen bolt
M20x1.5 (oil filter threads????)
M22x??? d-series countershaft nut
M28x1.5 - 14mm allen bolt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">
M18x1.5 is the O2 sensor bung
1/8 BSPT is the oil pressure sensor threads</TD></TR></TABLE>
Also, if it's an unusual thread, like the oil filter for example, Please put it like this
M20x1.5 (oil filter threads)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Because I'm down there right now ....
Front LCA Bolts:
Subframe flange bolt: 14x1.5mm
Bushing bracket flange bolt: 14x1.5mm
Bushing nut: 14x1.5mm
Shock fork lower bolt: 12x1.25mm
Shock fork upper bolt: 10x1.25mm
Swaybar endlink nuts: 8x1.25mm
Swaybar bushing bolts: 8x1.25mm</TD></TR></TABLE>
Thanks in advance.
See this guys post:
M12-1.5 -- lugnuts)
M16-???
Front LCA Bolts:
Thanks in advance.
#183
Yes I really need help please if someone knows a way to help me figure out the dimensions for the screws I need to replace my tensioner pulley for a 2000 Honda odyOdys. I took off the old one and misplaced the screws. They are like some type of 8 and 10mm. Please if anyone can help me out it would be so much appreciated....
#184
ANY ideas on the valve cover bolt sizes and dimensions, or whatever lol threads i guess, I broke one and stripped another its a 3.0 j30a
#185
any know the sizes for a valve cover bolt to use a helicoil i used a size ten socket to remove it so i thought it was the M10 helicoil but now im not sure, 3.0 v6 j30a1
#186
#187
Re: (Bense) 2000 crv lower alternator bolt ? My daughters is missing completely?
Sorry i lagged but schools been killer. Heres some not so common thread pitches that hondas have and if you ever screw them up is hard to find, so it better to have the correct pitch numbers then send out a stripped bolt asking "can you figure out the thread pitch"
Flywheel bolts (B and D the same, dont know about H and K): M12 x 1.0
Pressure Plate bolts (same b and d dont know about h and k): M8 x 1.25
Oil pan/Trans drain plug: M14 x 1.5
Trans case bolts that hold that little ball bearing in place with spring: M12 x 1.0 (oddly enough this is a hard tap to find, and timesert hasnt even made an insert for it yet so dont screw this one up)
Oil Pressure Sensor (back of block): 1/8 - 28BSP
Bumper screw/bolts: M6 x 1.0
Crank Bolt: M14 x 1.25
14mm Allen Bolt: M28 x 1.5
10mm Allen Bolt: M20 x 1.0
19mm bolt that connects rear trans bracket to trans: M14 x 1.5
If theres any other bolts that people would like to know let me know and ill get you the pitch.
#188
Re: (Bense)lower alternator 2000 crv length and pitch
#189
Re: (Prudz_lude)
How long are the bolts typically? I seen M6-1.0 x 12 MM on Amazon. Redoing my engine bay looking to replace with brand new bolts
#190
Re: (Prudz_lude)
In example, even the flywheel/flex plate bolts are different lengths. The automatic has shorter bolts while the manual has a bit longer bolts. Water pump has 3 shorter bolts and 1 longer bolt or vice versa.
Really, the only way to get the right bolt is to order it from Honda if you are after brand new.
#192
Would anyone happen to have the thread pitch and bolt size for the oil pan? Not the drain plug, but the other bolts. I’ll be replacing mine with the gasket and would like to put new bolts in.
#193
Re: (Bense)
I’ve lost one of the thermostat housing 10mm bolts
anyone know the pitch/what bolt I need
#195
Go Tigers!
I have actually spent a fair amount of time on this subject over the last few months. I hit my breaking point earlier in the year when I spent way too much time in my garage looking for an M10x1.25 nut. Since then I have ordered packs of washers and nuts that are most common to what Honda uses. In addition to that, I have ordered ones that are the same width, and that also have their flange nuts.
Here are the sizes, along with the McMaster-Carr part numbers. The first 4 parts are ones that are most common. All of these have heads that are the same width as what Honda uses. If you're like me, you can't stand when a nut that you normally use a 12mm socket on, requires a 13mm. So I've made sure that there's no funky crap in here (i.e. 11mm, 13mm, 15mm, 16mm, 18mm, etc)
M6x1.0 - 10mm - https://www.mcmaster.com/95108A107/
M8x1.25 - 12mm - https://www.mcmaster.com/95108A103/
M10x1.25 - 14mm - https://www.mcmaster.com/95108A105
M12x1.25 - 17mm - https://www.mcmaster.com/95108A104
I have had a few instances where I've needed an M14x1.5, so I'm adding these two.
https://www.mcmaster.com/4391N117
https://www.mcmaster.com/95003A214
Obviously, these aren't the only possible options. Additionally, you should know that Honda uses distorted thread lock nuts for things like suspension fork bolts.
#196
Re: (Bense)
May I know the size of the bolt screw connecting the throttle to manifold? honda city idsi is my unit .
Thank you
#197
Go Tigers!
Go Tigers!
Below is the original, first post of this thread. Which was last edited on on 3/6/07 16:12 EST. I am revising the first post.
See this guys post:
M12-1.5 -- lugnuts)
M16-???
Front LCA Bolts:
Thanks in advance.
See this guys post:
M12-1.5 -- lugnuts)
M16-???
Front LCA Bolts:
Thanks in advance.
