Cat converter help needed!!!
Ok so I need to replace the cat on my DC2 daily because it's shot (rattling like crazy and hurting power drastically) but I'm not sure how to find one as a direct fit for my setup. I want to keep it bolt in like it is now not weld in so that takes universal cats out of the running and a stock GSR cat would be the wrong size I'm sure. The setup is 95 GSR-B18C- RMF narrow header, USDM Type R Full cat back. It "looks" like my RMF header and a JDM Type R 4-1 are about the same length, so would a bolt in replacement for a JDM Type R fit this setup? Also my cat DOES have an O2 sensor in it currently even though I am OBD1. Any and all help is GREATLY appreciated.
Re: Cat converter help needed!!!
If that were the case there wouldn't even be a cat on my car lol. I have to do state inspection every two years in which they sniff for emissions and look with a mirror to see that there is indeed a cat body. Right now i don't have to go through again until April 2017 so I may just throw a universal test pipe in for now to buy me some time. I'm just worried that if I keep driving it clogged that I will either A) suck **** into my muffler and clog that as well, or B) burn up valves from having such excess pressure not being able to escape through the exhaust. Plus the sound at 1200-2000ish RPM is just plain embarrassing lol.
