Camshaft holder/holder plate hole is stripped and enlarged
Old 12-12-2012, 04:57 AM
Echelon's Avatar
Default Camshaft holder/holder plate hole is stripped and enlarged
So my was taking the motor apart to check the block since I lost pressure in cylinder 4 and as I'm taking apart the head I notice one of the bolts is extremely easy to remove, finish taking everything off and BAM...Anyway to fix this or am I **** out of luck?
Old 12-12-2012, 05:20 AM
thegr8one013's Avatar
Default Re: Camshaft holder/holder plate hole is stripped and enlarged
helicoil or just tap it with a biger bolt
Old 12-12-2012, 06:02 AM
Echelon's Avatar
Will the bigger bolt fit in the cam holder hole though? I'm taking my block into the machine shop I may just have them fix this...
Old 12-12-2012, 07:05 AM
mechanix619's Avatar
I wouldn't use a larger bolt because then you'd need to modify the cam cap as well; the less modifications the better.
At this point taking the head to a machine shop is the best bet. They'll probably fill and re-drill a new hole.
It's sort of hard to see but is the hole just warped at the top?
tegboy321
21
07-28-2013 02:58 PM
sh!ft
12-20-2009 05:02 PM
Hondaholik
07-24-2006 04:47 PM
sph33r
05-28-2006 05:59 PM
Lei Siew Long
09-27-2001 07:18 PM
Quick Reply: Camshaft holder/holder plate hole is stripped and enlarged
