BRAINSTORM: What would make a car die on idle and hard time starting again
Swaggylicious
This is an issue I've been having for at least the last 8+ months
Car: 2000 Civic Si B16a2, boosted, 5 year old dyno-tune setup by John Vega (phearable.net) *nothing changed in setup*
Issue: Vehicle will cut off either on idle or decel/coasting to a stop (spark cut). Will NOT immediately start again, sometimes it takes 3 cranks to start again...other times it would take 30 times (Video below showing what it does when I try to start it after it dies and I tried to start it again)
As I said, it will either die when I'm driving and I'm in neutral coasting to a stop or in idle. I've had instances where I literally let the car sit and idle and sometimes it will take 30 minutes to die, sometimes 3 minutes. But it will ALWAYS die, without warning.
What I've tried:
2 ECU's
New coil, icm,wires, plugs
A whole different distributor entirely
New engine wiring harness (issue is/was present even with old harness)
Several main relays
Known facts:
It will die ONLY on decel or idle,it has NEVER died on accel
It does NOT blow any fuses
Fuel pump ALWAYS primes when attempting to start again
AFR's does NOT change when it dies
Black/yellow wire on dizzy IS getting 12v
There is spark on ALL 4 cylinders
CANNOT be replicated manually
What I haven't tried:
I took apart and jiggle the **** out of the ignition switch, cant replicate it, I'm getting another switch from the junkyard this weekend
I'm trying to think simple mechanics as to what make a car die on idle/decel and it wont start again...i'm stumped
I'm at the point that if I cant solve this, I'm going to sell this car, it has been a nightmare. I've spent close to $1000+ the last 3 months on parts/labor/diagnostic with nothing to show
thought?
What I've tried:
2 ECU's
Several main relays
Known facts:
thought?
Swaggylicious
Re: BRAINSTORM: What would make a car die on idle and hard time starting again
Swaggylicious
Any check engine light on? Fuel system was the first thing that came to mind.
Swaggylicious
no check engine light as seen by the video
I'm not sure if this happens all the time but I BELIEVE, when i crank the car, the cel remains on but ONLY when it's cranking....i THINK...not sure, will have to double check on this
fuel prime and main relay click can also be heard everytime
i agree about the movement part, and that y i thought when you were on decel there maybe a bit of movement depending on rpm i guess,I dont know the shape of your mounts, and I dont think you would necessarily pop a fuse but just my 2 cents.
Hmmmm, when's the last time you changed the fuel filter?
Also, I think you would need an IACV off a b16, but I'm not certain on that. I know when mine was bad, it would die whenever the rpms would get under 1000.
I had the same issue on my B18c-r. Got a IACV off a D series at the junk yard, fit just fine but same issue. Cleaned out my denso IACV and the D series IACV with throttle body cleaner, tried both again and still nothing. What I ended up doing was just turning the idle up on the throttle body about 400rpm and it stopped.
Swaggylicious
I cross referenced the part no, seems like a single cam vtec has same iacv
Swaggylicious
Swaggylicious
Gotcha ,im guessing counterclockwise is higher
Also, so you had the same exat issue? Like it literally dies on idle/decal randomly and turning the idle up fixed it?
Did u have the same restart issue like the video?
Mine wasn't as bad at restarting but yeah, after cruising on the freeway it'd almost always die while coasting on an off ramp, and city streets it'd die rolling up to stop lights in nuetral. It progressively got worse and worse till I finally raised the idle. It used to idle at 900rpm but it'd randomly die while sitting or coasting in nuetral and I'd have to rev it to get it started again. After rasing the idle to 1300 it doesn't die anymore. And I dont remember which way to turn it to raise or lower idle. I just let it sit and idle while I tinkered with the screw, drove it, tinkered with it, drove it, just going back and forth with that till I found the lowest rpm it wouldn't die at.
What about cleaning the throttle body? Shouldn't we focus on fixing the underlying issue?
Check your spark plugs to see if you're running too lean or too rich.
Have you tried putting in new spark plugs?
Swaggylicious
Swaggylicious
Yes, there's a new set in there now...still cant get it to start again
Hoping to get it towed to my tuner tonight...we'll see what he finds
Moderator
Sorry. looks like someone hit me with a tazer when typed that. Meaning to say IACVs don't really die on these 2000 Civic Si. Not to say that it won't happen, just that its unlikely. I'm the original owner of mine, and still have yet to experience any issue from that device.
Your symptoms seem more indicative of a failing / malfunctioning fuel pump.
Swaggylicious
Dropped the car off at my tuner last night, hopefully he can pinpoint the issue
My vote is for IACV or related circuits....
If it was the fuel pump the issue would most likely occur under a load (accel)
