Bad TPS
Old 10-27-2015, 12:03 PM
Em1Trevor's Avatar
Default Bad TPS
My TPS is bad on my daily. I don't wanna just get the sensor, I wanna get the trottle body with it. Cheapest I saw oem new is $250. Black Works Racing has one with TPS for $115. I'm going go with the BWR. Has anyone ever used the BWR throttle body? It's going on my D15B Vtec.
Old 10-27-2015, 03:11 PM
holmesnmanny's Avatar
Default Re: Bad TPS
TPS's almost never go bad. How do you know it's bad.
Old 10-27-2015, 04:36 PM
Em1Trevor's Avatar
Default Re: Bad TPS
The idle is all messed up, check engine light is on and TPS code is what I get.
Old 10-28-2015, 06:44 AM
spAdam's Avatar
Default Re: Bad TPS
More likely to be a wiring issue. Start with the sensor ground, go through everything.
Old 10-29-2015, 05:02 AM
Nottheonion's Avatar
I wouldnt buy a bwr gasket let alone throttle body
Old 10-29-2015, 06:27 AM
spAdam's Avatar
Default Re: Bad TPS
Fact.
Old 10-29-2015, 06:59 AM
RTFM
v4lu3s's Avatar
Default Re: Bad TPS
Get your service manual out and follow the tps troubleshooting guide.
Old 10-29-2015, 10:09 PM
slowcivic2k's Avatar
Default Re: Bad TPS
Throttle sensors rarely fail, and when the sensor actually does, it is usually met with symptoms like: "It falls on its face at part throttle, but if I press harder, it goes just fine."
The vast majority of TPS wear is just off-idle, and part cruise, this is where you should expect problems. Wiring problems can cause TPS problems at any point, and it is best to check there first. If your power and ground are good, use a multi-meter and test the signal wire for abrupt changes in resistance as you go from closed to WOT with the engine off, key on. Reference the specifications for the sensor.
01_ITR
01-16-2009 07:22 AM
valentine97
19
01-15-2008 10:33 AM
geogal84
10-23-2007 02:41 PM
GSRcivicGSR
12-20-2004 04:29 AM
98teg
06-04-2002 04:25 PM
Quick Reply: Bad TPS
