Oil filter won't stay tight?
Old 06-03-2010, 02:39 AM
Big Cat
fatboy1185's Avatar
Default Oil filter won't stay tight?
I've done numerous oil changes before, and I always tighten down the oil filter by hand, as tight as I can get it. Well I changed my roommates oil today, and it started leaking bad, so I crawled under there, checked the oil filter, and it was loose. Re-tightened it, told her to start the car while I was under there, and watched as the filter slowly rotated backwards from the vibration of the engine. Anyone ever had this happen? The filter is a Fram tough guard.
Old 06-03-2010, 03:19 AM
Big Cat
fatboy1185's Avatar
Default Re: Oil filter won't stay tight?
Never mind, just checked the old filter, and the O-ring is missing, so it must still be stuck to the block. Never had an O-ring come off the filter before.
Old 06-03-2010, 10:25 PM
seanbev24's Avatar
Yep, always make sure the old gasket doesn't stick on there. Glad you figured it out before it was too late.
Old 06-04-2010, 10:08 PM
pm4nudes
chewyv's Avatar
that wouldve been pretty bad if you didnt figure that one out!
Old 06-04-2010, 11:06 PM
dntnedvtec's Avatar
The O-ring-stuck-to-the-block deals huh? Happens to the best of us. I left my old Apt. a mess because of that...Good times.
devin_hoang
36
03-24-2009 01:08 PM
00ls1
08-01-2008 07:48 PM
Noch
07-26-2008 01:47 PM
digdug18
30
09-13-2005 05:12 PM
TeGGY_LS
08-06-2004 01:16 PM
Quick Reply: Oil filter won't stay tight?
