Anyone know the best way to test a vacuum system for leaks????
ok just need to know what is the best way to check a vacuum system for leaks
is there a pump or something you can make or use compressed air ????? someones gotta know
the only way i was told my one of my friends is to take carb cleaner and spray hoses until the car chokes but i dont want to do that
i wanna be able to put air through the system and hear for the leaks anything like that so if anyone knows please let me know ASAP thanks
Re: Anyone know the best way to test a vacuum system for leaks???? (DeDonDeRosa)
Many of the systems that are attached to vacuum hoses are supposed to be blocked off when the car's off. You can use a MityVac to check each one to see if it leaks. That's kinda tedious...
Take a propane torch, NOT lit. Spray propane around the manifold & anyplace that you suspect. Idle will increase when it sucks propane into the engine. There's a fire hazard, so use some care & common sense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa »</TD></TR><TR><TD CLASS="quote">ok just need to know what is the best way to check a vacuum system for leaks
You asked for the best way, that's it.
i take the easy approach, and if it seems like i have a vac leak, i replace all my lines....vac line is chap and easy to replace. Also if 1 line is going then the rest might be going soon too
Re: (IO_303)
i have tried all the procedures everyone else is saying and they are right. you do have to be careful though cuz you can start a fire. Another method you can do is use a stethscope and listen for leaks. no potential fire hazard doing it this way.
Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">There isn't much vaccum on a modern honda motor anyway... what exactly are you looking for?</TD></TR></TABLE>
if you dont have much vacuum you got problems
how much vacuum should a "modern" honda motor have??
