GSR swap Fuel issue? Cuts out at lower RPM?
I recently bought a 97 hatch with a GSR swap car ran pretty good when I first drove it. The more I drove it the worse it got. Car bucks and cuts out violently upon acceleration at lower-ish RPM but stays running. And purges on idle. I replaced TPS and MAP sensors along with new wires and plugs hoping to fix the issue which it did not. After about 5 minutes of the car running I pulled the new spark plugs and all of them were completely black.
Re: GSR swap Fuel issue? Cuts out at lower RPM?
What engine management are you using ? You said that you swapped the MAP sensor and there is no change... what throttle body do you have ?
supracrx
10-29-2006 10:00 PM
