Acura Integra & 92-95 Civic injectors interchangeable?
Old 03-18-2009, 06:19 PM
WheelPowerRacing's Avatar
Default Acura Integra & 92-95 Civic injectors interchangeable?
I am building a LS/VTEC using a GSR head & bare GSR stock intake. I am trying to utilize parts already in my possession (my build is way over budget!) and my question is can I use a set of 1994 Civic (D16Z6) injectors I already have? I think they are both 245cc? Both are OBD1. Any information would be helpfull. Someone said I needed GSR or Type R injectors for performance reasons. Is there a difference? I have a stock B16 fuel rail and pressure regulator that appear to be usable with the GSR intake also.
Old 03-18-2009, 06:26 PM
non-VTEC's Avatar
Default Re: Acura Integra & 92-95 Civic injectors interchangeable?
you can use those injectors no problem. they are exactly the same.
Old 03-19-2009, 06:15 AM
Fibercation's Avatar
what he said^
Old 03-19-2009, 11:37 AM
Thanks, the build continues!
Old 03-19-2009, 06:38 PM
Took the injectors from the D16Z6 intake I had and the bottom seals and they fit. The bottom seals out of the newer B16 intake i had were about 1/2 as thick and set too deep. I knew the D16Z6 fuel rail would not work as the injector spacing is greater on the GSR manifold. So I used the fuel rail from the newer B16 intake, but it set too high with the 3 mounting spacers. I removed the spacers and it seems to fit/work. Question is, what is the purpose of the plastic spacers and am I setting myself up for trouble by mounting the fuel rail without them? I would hate to have high pressure fuel spraying all over my hot freshly rebuilt engine.
93 Eg Couper
08-04-2010 05:58 PM
crxricer66
10-18-2007 06:52 AM
EGBuddy
12-21-2006 11:33 PM
crx.com
01-04-2006 06:36 PM
fsck3r
12-14-2002 01:46 AM
Quick Reply: Acura Integra & 92-95 Civic injectors interchangeable?
