Suspension & Brakes Theory, alignment, spring rates....
Why do people spend so much money on lowering/suspension but...?
Old 08-18-2008, 09:13 AM
dfoxengr's Avatar
Default Why do people spend so much money on lowering/suspension but...?
Dont worry about how much theyre reducing their bump travel?
Can we have a conversation about why this happens?
I mean why spend 600$ on something and then complain you're hitting your bump stops, or risk bottoming out the shocks?
Old 08-18-2008, 11:24 AM
206 EH2's Avatar
Default Re: Why do people spend so much money on lowering/suspension but...? (dfoxengr)
for show/bling.
They wanna ride low and have sweet brand name suspension but don't want to have it set at an actually functional level.
Maybe, maybe not. My guess is as good as yours.
Old 08-18-2008, 11:32 AM
dfoxengr's Avatar
Default Re: Why do people spend so much money on lowering/suspension but...? (206 EH2)
see thats what I think too, but then you even have guys that auto-x and DE their cars and still dont do the right thing.
maybe a lot of people dont know it is necessary?
but it just kills me when they say, I have such and such suspension and I cant keep it off the bumpstops due to potholes, or racing, or whatever
Old 08-18-2008, 11:33 AM
VTECIntegra9's Avatar
it's as undetermined as how many licks it takes to get to the center of a tootsie pop
Old 08-18-2008, 11:35 AM
dfoxengr's Avatar
Default Re: (VTECIntegra9)
but I can goto the store, and 3 hours later have that answer, lol
Old 08-18-2008, 02:57 PM
hondadriver's Avatar
Default Re: (dfoxengr)
The question should be, WHY THE F don't any shock company's make shorter shocks for us? I know koni can make a custom shock with what ever setting you want and maybe a shorter shock tube. But why is a custom shock our only option. we have bilstein, KYB, koni, tokico, dropzone and monroe. And NO ONE offers a shorter shock housing. I mean do these companies think people are buying their expensive shocks and putting them in their modified cars on stock springs? And everyones warranty is "if vehicle is lowered more then 1.5", warranty is void" WTF. 8 outta 10 modified cars are lowered way pass 1.5", so why can't these shock companies make something that is made for this purpose. You would think after all these years of people driving their slammed cars and having problems with bottoming out SOME company might have a product out there made to solve this problem.
Old 08-18-2008, 04:32 PM
dfoxengr's Avatar
Default Re: (hondadriver)
good point. does the shorter body allow for any advantages over the top hats?
seems to me that a shorter body would increase bump travel but decrease droop.
Modified by dfoxengr at 8:38 PM 8/18/2008
Old 08-19-2008, 10:17 AM
PatrickGSR94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadriver &raquo;</TD></TR><TR><TD CLASS="quote">The question should be, WHY THE F don't any shock company's make shorter shocks for us?
There already is a solution - a short-body full coilover. Whether this is the best option or not, however, is up for debate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">good point. does the shorter body allow for any advantages over the top hats?
yep, this is what the short-body full coilovers do.
Now really, your bump travel is physically limited by the size of the inside of the shock tower. At a given ride height, you will ALWAYS have the same amount of bump travel from the at-rest upper control arm position to the point of the UCA hitting the shock tower above when the suspension is compressed. That is, of course, assuming your shocks don't bottom out on bump stops first. If you have extended upper mounts, then your are more likely to hit the shock towers before the bump stops, anyway.
And speaking of short-body shocks, there used to be one on the market from GAB. It was an OEM-style shortened body shock absorber for Civics and Integras, which I think may have been adjustable for either bump or rebound or both. There may have been a non-adjustable version, as well, but I'm not sure on that. But those have long since been discontinued for some years now (probably since the late 90's).
Other options for increased bump travel and lowered ride height are moving the wheels higher up on the knuckle (like drop spindles for trucks). I have seen some custom knuckles for Civics and Integras, but I'm not sure if they were really marketed to the public.
Another product from back in the day is the old Suspension Techniques DropForks. This was a shorter version of the OEM front shock forks that could get the car lower even on factory springs and shocks. This would maintain the same distance from shock body to shock tower, therefore maintaining the same amount of bump travel (or increasing it if you had coilovers and could raise the spring perch by the same amount as the fork dropped the ride height).
If you have Koni shocks, you can do the fork trick, which essentially does the same thing as the old DropForks did. By sliding the fork a little higher up on the shock, you can get the car lower while still maintaining the same bump travel on the shock piston.
But again, all of these are still limited by the clearance from the UCA to the shock tower. There's really no way to change that unless you cut holes in the towers and maybe weld new sheetmetal back into place to create more room.
But again, there are physical limitations to everything. And when you start doing custom shock tower enclosures, you could possibly run into problems of not enough movement in the stock upper ball joint, and the axles hitting the frame rails. The ball joint stud can only move so far the higher the UCA goes, and at a certain point it just won't go anymore without breaking. But your CV axles would probably hit the frame rails before you reached the limitations of the ball joints anyway.
So there are always compromises to be made here or there when working with a stock-chassis vehicle. There really is no way to get everything you need/want unless you do a full tube-framed front chassis with custom upper/lower control arms, etc.
Old 08-19-2008, 11:36 AM
Default Re: (PatrickGSR94)
Yeah, FULL coilovers. But not everyone buys full coilovers. Hell, HT people swear by the GC/koni setup and i bet about half the people on here are running that setup. Theres name brand and no name coilovers, and theres name brand and no name lowering springs. I just think there should be a shock design that is AT LEAST 1" shorter then OEM.
I like the drop-fork idea. When i had the bottoming out problem I did alot research to try and solve the problem. I remember reading about the drop-forks, but by the time i found them noone was selling them. So I just did the tophat extention and lowered the shock inside the fork. SO my problem was solved, but its stupid that we have to have a DIY like this just to solve our problem.
Amagine if companys came out with high lift cams, but no improved valve springs. You can install the cam and drive with it, but if you go into to vtec (high lift) you might get valve float, and if you blow ur motor its your problem. Same thing with shocks, yeah our shock are $100 each, and their going on our modified car, BUT if you lower your car pass 1.5" and they blow its all on you. What i mean is, if companies can make proper valve springs for high lift cams, someone should make proper shocks for coilovers/lowering spring. So peoples only option isn't full coilovers.
Old 08-19-2008, 12:29 PM
slammed_93_hatch's Avatar
That still doesn't slove the problem of the UCA hitting the upper fender well.
And shorter shocks= less stroke and in general this sucks for honda's.
You can shorten some what but not like the JDM coilover do, at least IMO/E.
It's simple really people just need to run higher spring rates. (hence why most JDM setups run pretty stiff springs, they have NO stroke.
Old 08-21-2008, 08:25 AM
obnoxiousls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadriver &raquo;</TD></TR><TR><TD CLASS="quote">The question should be, WHY THE F don't any shock company's make shorter shocks for us? I know koni can make a custom shock with what ever setting you want and maybe a shorter shock tube. But why is a custom shock our only option. we have bilstein, KYB, koni, tokico, dropzone and monroe. And NO ONE offers a shorter shock housing. I mean do these companies think people are buying their expensive shocks and putting them in their modified cars on stock springs? And everyones warranty is "if vehicle is lowered more then 1.5", warranty is void" WTF. 8 outta 10 modified cars are lowered way pass 1.5", so why can't these shock companies make something that is made for this purpose. You would think after all these years of people driving their slammed cars and having problems with bottoming out SOME company might have a product out there made to solve this problem.
You haven't seen skunk2's shock? Might not be the best out there but it does have a shorter body. I have skunk2 shocks and springs on my dc2. It does ride pretty rough but doesn't bounce. And I rarely ever bottom out.
Old 08-21-2008, 09:28 AM
Default Re: (obnoxiousls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obnoxiousls &raquo;</TD></TR><TR><TD CLASS="quote">
You haven't seen skunk2's shock? Might not be the best out there but it does have a shorter body. I have skunk2 shocks and springs on my dc2. It does ride pretty rough but doesn't bounce. And I rarely ever bottom out.</TD></TR></TABLE>
Oh cool I didn't know they had those. Although they are non-adjustable, I would be interested to know how well they hold up with the stiffer spring rates of the coilovers or race springs.
Old 08-21-2008, 10:13 AM
bmoua's Avatar
i had a set of the sk2 sports shocks for 2 weeks, depending the drop height if your running any spring rates lower than 6k you'll have bottoming out issues. I paired the sk2 shocks with ground control's w/ OTS civic rates and man did i have bottoming out issues. I was tucking a little more than 2inchs in the front and rear.
Modified by bmoua at 11:23 AM 8/21/2008
Old 08-21-2008, 10:38 AM
Default Re: (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">
TUCKING 2 inches?!?! Well that was your problem. I'm surprised you had ANY suspension travel at ALL.
Old 08-21-2008, 11:36 AM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
TUCKING 2 inches?!?! Well that was your problem. I'm surprised you had ANY suspension travel at ALL.</TD></TR></TABLE>
well the shock did sit quite lower than a regular aftermarket shock and sk2 did state their sport shocks can handle up to a 2.5inchs. I believe the shocks valving was to soft, my spring rates was too soft to run it that low as well.
Old 08-21-2008, 12:52 PM
TunerN00b's Avatar
Default Re: (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
No, but this does...
Old 08-21-2008, 02:14 PM
luciferi's Avatar
Default Re: (TunerN00b)
That really doesn't solve it either. Now the whlole arm bottoms out instead of just the end of it. A custom a-arm with a modified spindle is the answer
Old 08-21-2008, 03:04 PM
Default Re: (luciferi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luciferi &raquo;</TD></TR><TR><TD CLASS="quote">That really doesn't solve it either. Now the whlole arm bottoms out instead of just the end of it. A custom a-arm with a modified spindle is the answer</TD></TR></TABLE>
And neither of those solutions addresses the axle hitting the frame. Once you allow even more movement of the suspension, the next thing to hit is the CV axles.
Old 08-21-2008, 04:16 PM
TunerN00b's Avatar
Actually, the arm won't hit. The tire will fully bottom itself out into the fender before the UCA hits.
We extend the shock upper mount (or move the shock lower mount lower) and while it does create more bump travel, we do change the point of contact from the shock to the UCA.
Then, we cut the shock tower (and hopefully reinforce and box the opening, which that picture I posted does not show) to allow the UCA to move up into the engine bay. Again, we've added additional bump travel, but have now moved the point of contact to the tire itself.
Of course, running a smaller diameter tire could then be used to further increase bump travel, but, yeah.
And yes, a shorter spindle (knuckle, upright) and a relocated UCA (move the pivot point down the same amount of spindle shortening) would partially solve the issue, but not as much as you would think at first. The point of contact would then be the tire, which is only 1/2" from contact from the metal inner fender when the UCA hits anyway. So, now we've moved on to $$$ custom parts for a 1/2" gain in bump travel. We've also potentially ruined the geometry of the suspension, doing lord knows what to the IC, RC, camber curbe, toe curve, etc...
Oh, the joys of trying to force an economy car to do something it was never designed to do...
Old 08-21-2008, 05:00 PM
luciferi's Avatar
Those who actually get to the point of modifying arms and spindles usually have already cut out where the axle and tire hits. . I was just trying to point out you have to modify those, not just cut a hole, if you want full travel.
Old 08-21-2008, 08:15 PM
tienzien's Avatar
well i had a good suggestion from my friend. depending on the car you have, this option may not be for you. luckily i own an ek and i run crx's shock which is shorter in the front. only thing need to be done is swapping out the forks and you got yourself a direct bolt on.
Old 08-21-2008, 09:06 PM
bmoua's Avatar
Default Re: (tienzien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tienzien &raquo;</TD></TR><TR><TD CLASS="quote">well i had a good suggestion from my friend. depending on the car you have, this option may not be for you. luckily i own an ek and i run crx's shock which is shorter in the front. only thing need to be done is swapping out the forks and you got yourself a direct bolt on.</TD></TR></TABLE>
can anybody vouch for this?
isn't the different shock valving going to make any aftermarket shock underdampened with the extra weight put on.
Old 08-22-2008, 07:28 AM
Maybe a Koni Sport adjustable shock for a CRX (if they make those) would work?
Old 08-28-2008, 04:25 AM
dfoxengr's Avatar
so then why dont people who know about this issue just do the quick cheap fix of top hat extension?
Old 08-28-2008, 04:43 AM
Whats Up DOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
Oh, the joys of trying to force an economy car to do something it was never designed to do...</TD></TR></TABLE>
Doesn't cutting the shock tower reduce the integrity of the shock tower? I would be afraid to do that. Not only for safety/insurance issues, but u have the UCA mounts right there- when you go over a bump or load the chassis u get even more geometry deformation than stock
Best bet IMO is to do two things- 1, run a shock with a shorter shaft like the Koni Yellows or Skunk2s, 2- do a top hat mod or use some funky combination of parts like the EK shocks and EF fork, etc
It would be cool if someone could get a bunch of stock suspensions to compare what fits on what and what setup creates the most travel
Quick Reply: Why do people spend so much money on lowering/suspension but...?
