WARNING: NSX caliper inside!
The back-inner side of the rotor got bad worn (due to slightly bad wheel bearings, replaced!)so I got the rotor resurfaced, and the PADS got 90% meat left.
Question:
Should i get new pads? if yes, wat brand? NSX OEM cost $150 F**@#(@*&#! Does ACCORD, TYPE R, S2k, TL, CL, Legend pads also fits?
Does the SLOTTED rotor has DIRECTION? (like directional tires)
thanks guys!
be professional
Re: WARNING: NSX caliper inside! (polything)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by polything »</TD></TR><TR><TD CLASS="quote">The back-inner side of the rotor got bad worn (due to slightly bad wheel bearings, replaced!)so I got the rotor resurfaced</TD></TR></TABLE>
You'd better hope that it's straight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">and the PADS got 90% meat left.
Question:
Should i get new pads?</TD></TR></TABLE>
If you don't, the pedal and the brakes are going to feel like crap until they wear in.
You should replace the pads every time you resurface or replace the rotors, unless they've have almost zero use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">if yes, wat brand?</TD></TR></TABLE>
What pads are you using currently, what car, what power, what purpose, what price range, and what aspects of braking are you looking to improve by changing pads?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">NSX OEM cost $150 F**@#(@*&#!</TD></TR></TABLE>
You play with big boy toys, you pay big boy prices.
If you think that's expensive, you should see what the OEM Ferodo pads cost for '04+ TLs with the Brembo calipers . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Does ACCORD, TYPE R, S2k, TL, CL, Legend pads also fits?</TD></TR></TABLE>
NSX front calipers use FMSI D503 pads, so pads from any car using Nissin 17CL15VN calipers will fit ('97-01 ITR, '97-01 CR-V, '97-99 3.0CL, '96-98 3.5RL, '95-98 2.5TL/3.2TL, '95-98 Odyssey, '95-97 Accord V6, '92-94 Vigor, '91-97 Accord wagon, '91-95 Legend, etc.).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Does the SLOTTED rotor has DIRECTION? (like directional tires)</TD></TR></TABLE>
No. It doesn't matter.
Question:
Re: WARNING: NSX caliper inside! (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
No. It doesn't matter.</TD></TR></TABLE>
Yes it does. It all depends on the company. Look at how they are on the NSX and put them the same way on your car.
Banned
The internal vanes should rotate in such a manner that they create an internal airflow from the inside of rotor to the outside, not the outside to inside (or cooling will be somewhat impaired). This means the leading edges of the vanes should start on the inside of the rotor.
I'm cheap, and have been known to sand and / or machine damaged or unevenly worn brake pads back to a flat / parrallel surface. Pads can be clamped t a faceplate on a lathe and machined flat, or sanded on a plate (then checked for squareness with a vernier caliper). Pads 're-condidioned' in this way act more or less like new pads.
The only proviso is that I would avoid using pads that had been severely overheated. You also need to be conscious of any dust you might produce because you don't really know what materials might be in any given pad, i.e don't produce it if possible (water during sanding), and use a respirator (just in case).
