SLAMMED... Suspension Setups.
#3577
Re: SLAMMED... Suspension Setups.
And can't afford the hobby? You realize you're talking about modified Hondas right? 90% are just economy 10+ year old shitboxes that aren't worth more than a few grand
Ps... Take a guess at what suspension setup this car has. I'll give you a hint, it's jb welded
#3579
Guys with koni/ground control set up? Slammed/wheel tuck or even stance? I need some ideas, advice on what custom rates to get. I got 95 civic hatch with koni yellow. I'm thinking 550F/450R OR 525F/450R. I'll also be getting jdm itr rear sway bar with asr brace and f7 lca.
#3580
My DA in 2012
Koni yellows for an EF, ground control coils, EF forks, 2" front and 3" rear entented top hats, these were maxed out at full height, I couldn't go any heigher if I tried, the punch welds were 1" off the ground, STATIC
Then I put 16" rims on it in 2013 and it went up a little bit
#3583
#3587
Hello, guys I need help I need to find out what coilovers are best for me I wanna go slammed but have a good ride no bounce or too stiff, I've been asking friends and reading review and forms but there's a lot of options. I have a price range of $1500 and am open to all ideas or help. Thanks
#3588
#3589
D2 Super Low Coilovers (rear maxed out & front messed with preload)
16x7 ~20 offset (Not sure of the offset because rims didn't say it and I'm also using 4x100 to 4x114.3 25mm adapters.
165/45/16 tires.
AlexLude
03-25-2004 07:14 AM
