Suspension & Brakes Theory, alignment, spring rates....
what 22mm sway bar is this comptech ?
Old 09-30-2010, 05:10 PM
99gsvtec's Avatar
Default what 22mm sway bar is this comptech ?
I just ordered what was supposed to be usdm ITR Integra Type R 22mm sway bar, so I ordered all the grommets n d brackets from dealer, the bar shows up with no place for grommets where end links go ... will this even work ? Are the ek 96-00 civic & integra bars interchangable I understans the subframe braces are different hints why complete asr ct engineering etc have different part numbers between 96-00 civic vs 94-01 integra Will this even work on my dc2 chassis ? I mic'd the bar checks out at 22mm but stumped how to attach end links Mind u this has a fresh coat of rattle can black
THIS IS HOW OEM ENDS ARE !
Old 09-30-2010, 06:03 PM
TunerN00b's Avatar
Default Re: what 22mm sway bar is this comptech ?
The comptech bar has multiple endlink mounting points. 3 per side. So, it isn't an Integra Comptech bar.
I know nothing of EK to DC fitment though...
Old 09-30-2010, 07:53 PM
99gsvtec's Avatar
Have a feeling this guys gonna screw me out of my $ his other ebay items are gone but shipped it from his work ct engineering lol Ill throw the **** through the window lol
Old 10-01-2010, 06:24 AM
phunhaus's Avatar
It could be an EK9 CTR sway bar.
Old 10-01-2010, 07:38 AM
six7one's Avatar
try using adjustable endlinks it might help
Old 10-01-2010, 07:42 AM
99gsvtec's Avatar
I thought they were similar to other OEM Honda bars the hoop en for grommet ?
Old 10-01-2010, 07:43 AM
99gsvtec's Avatar
Ya well shouldnt have to buy $50 endlinks that might not work, I dont even know if this is an Integra bar bends look like it but idk fir sure
Old 10-01-2010, 08:34 AM
phunhaus's Avatar
Since the EK endlinks are different than EG/DC2 that might not be the case.
DC2 ITR shown with bushing/collar:
EM1 shown without bushing/collar:
I will now put money on it being a CTR sway bar. Will the bolt not go through the hole or something? What is the problem you're having with installation?
Old 10-01-2010, 09:35 AM
wannaBjdmca6's Avatar
its a CTR one
Old 10-01-2010, 10:36 AM
I'm not Rick!
rick_rabies's Avatar
almost looks like the old school sway techniques one.
WHERE CAN WE GET TURNBUCKLE ENDLINKS?
Old 10-01-2010, 11:04 AM
Master Detailer
98civdx's Avatar
Has to be a ctr bar.
If you can put integra rear sway bars on civics I would guess you could use civic on integra.
But you won't be able to run integra endlinks.
You would need something like a blox endlink.
rubydc2
Texas -OK -LA (Sales)
16
07-11-2010 08:55 PM
Crank
Northern California (Sales)
20
02-22-2010 01:42 PM
kcjohnnyboy
Suspension & Brakes
30
08-27-2007 01:10 PM
Jonmon
02-12-2003 01:44 PM
Quick Reply: what 22mm sway bar is this comptech ?
