Suspension & Brakes Theory, alignment, spring rates....
Lower Control Arms
Old 06-24-2006, 11:12 AM
DSMRacing's Avatar
Default Lower Control Arms
So I was in the process of lowering my car and when I got to the rear it came out the bolts were frozen to the bushings. So I ordered Omnipower LCAs and was wondering if it'd be alright to replace with the stock LCAs while having stock shocks. Most cars I've seen, the shocks have also been replaced. Would I also have to replace my shocks when putting in the Omnipowers?
Also, there is no place to bolt on the sway bar to the LCA like there is on the stock one. Is there an alternative for this or do I just have to manage without the swaybar? Need a reply pretty fast as I plan on doing all this today and I've read about how long it takes to take out the frozen bolts.
Thanks in advance.
Old 06-24-2006, 09:59 PM
gabebauman's Avatar
Default Re: Lower Control Arms (DSMRacing)
That's wierd...the Omni LCA's should have the the hole for the sway bar endlinks.
Modified by gabebauman at 1:11 AM 6/25/2006
Old 06-25-2006, 09:12 AM
OMG THE GOGGLES's Avatar
Hes weird, they do have the hole, anyways, stock/aftermarket LCA's are the same. Just lighter, stronger, and damn so goood looking.
Old 06-25-2006, 09:20 AM
Joon Joon's Avatar
Default Re: Lower Control Arms (gasper44`)
with those u gotta run a different bolt.. u gotta have a bolt and a nut.. theres no threaded part ont he arm like the oem ones..
Old 06-25-2006, 02:30 PM
DSMRacing's Avatar
Default Re: Lower Control Arms (LFA Squad :: Joon Joon)
Thanks for the replies. Yeah I was thinking that's the hole for the sway bar. It was more common sense, was just wondering if it'd actually work with a new bolt and nut because I haven't even put the LCAs on.
Old 06-25-2006, 05:19 PM
be.twenty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSMRacing &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the replies. Yeah I was thinking that's the hole for the sway bar. It was more common sense, was just wondering if it'd actually work with a new bolt and nut because I haven't even put the LCAs on.</TD></TR></TABLE>
yes it will work with a new bolt and nut..
be sure to get a high grade bolt and nut so it doesn't break or crack when it's under pressure.
boosteddb1_808
08-29-2010 03:07 PM
im_inn0c3nt
07-16-2010 09:52 AM
sinfulj32
Suspension & Brakes
07-23-2006 03:30 PM
DSMRacing
06-24-2006 02:40 PM
GoQkRaCeR
05-01-2004 04:47 AM
Quick Reply: Lower Control Arms
