inexpensive 6" race coil springs in 300lb/in or 5kg/mm rates?
i have a couple months so ill keep looking in for sale section just seeing if maybe there is an option im missing. skunk2 comes close with a 6kg option and eibach likley makes some just dont want to spend much money. any other options for a 6" 5kg-5.5kg?
Re: inexpensive 6" race coil springs in 300lb/in or 5kg/mm rates?
ERS springs are usually around $50-$60 each for normal linear-rate suspension springs (not tenders or helpers). Are you looking for cheaper than that?
Found these in 6", they have plenty of options. $59 each.
http://www.ground-control-store.com/...gory.php/CA=48
thank you for basically corroborating what i have found in my searching; most options are ~60$ i just need to accept it. with most people wanting to upgrade spring rates, i should be able to find someone swap with in the coming months.
I have been trying to swap springs with someone for a long time. No one seems to want to, maybe you'll have better luck.
the $60 the springs cost really isn't that bad. At least I don't think so.
